been flying just over a year, to the stage now where im doing fast figure of eights, forward flight pirroettes and a bit of backward flying, what do i do next? just got myself a trex 600 to hopefully help me progress, been using pheonix quite a bit and find i can do the tricks on there how does it compare with regards to stick movements?
first tricks to learn
T-Rex 600LE - canomod - OS 50 - Spartan DS760 - 610's, 650 tail, NHP's-Spektrum Telemetery-Rapicon20%
Raptor 60 - Hatori - 401 - BBT 710's NHP 105's MD500 scale fuselage
Align 450pro stock
Trex 700LE - FBL- RJX Head - OS91sz - 610s, BEASTX V3 - 650 tail - 30% Optifuel
Trex 250 new edition to the family
Pheonix 3.0s
Spektrum Dx8 v2.0 DSMX
sigpicTags: None
..also working on orientations..flips into and out of inverted front/back/each side tail-in nose-in and sides-in in-between which I'm trying to improve my aileron ticktocks and starting backwards flying now the inverted forwards is solid...
The hardest excercise for me is doing it all v e r y slowly...fast piro's easy but try doing a 30sec level piro on the spot in gusts...PGK
Been practising this for months, starting to get really good and it helps loads with everything else.Originally posted by pgkevet View PostThe hardest excercise for me is doing it all v e r y slowly...fast piro's easy but try doing a 30sec level piro on the spot in gusts...
Try some stall turns, advancing to double turns
Raptor 30V1 Maverick Head
OctoCopter
Futaba 14SG
probably same as above, practicing orientations and turning away and back towards me (if that makes sense) think a reverse '8' - this my old brain struggles with.
I would try loops, stall turns and aileron flips if your looking for a bit of 'wow' factor. Not to difficult, give yourself plenty of height tho, particularly on the flips.
The first thing I did after figure 8's was a backflip. If you can do that in Phoenix then just get in a stable hover with a good bit of height, think it through in your mind for a second and then go for it. The stick movements are certainly very similar to Phoenix but it's just a bit more nerve wracking in real life.
all the above is very good advice.
One hint: always find the most difficult variant.
For example circles. Clockwise or anti-clockwise. Which one is harder? That's the one you should practise. Forwards, backwards or side-in?
It's a long-term project, but it pays off, especially if you're serious about 3D (and then, the same inverted...). Once you go to piroing flight (snakes etc) you have to know each and every one of them by heart. So start early.Woohoohoohoohoohoohoohoohoohoohoo -Barbra Streisand
x 3
