sorted the tail
  • sorted the tail
    Here a follow on question from an earlier post.I think I've sorted the prob I had with the tail it seem quite solid now,Even in the quite strong wind I have here tonight.The problem is now when I give rudder input it works fine until I stop ruder input,Then it gives a bit of a wag than settles.
    Jim
    Turn the gain down a couple
    Trex 250 se, DFC, 3GX.
    Trex 500 esp, FBL, Beastx.
    Trex 600 nsp, DFC, Beastx.
    Compas 7HV, 120HV YEP, SK3 560, HV MKS, VBAR.
    Squall (less 1 wing).
    DSX9.
