Well chuffed with msr
  • Well chuffed with msr
    Just got my msr today,ordered yesterday from fastlad,Had a go and i'm well chuffed.How much simpler could things get.
    How long should I fly the batteries for?
    Do I need to do anything to the tx settings,dx6i?
    Don't think i'm going to be leaving the house for a long time
    Jim
    I run mine on 160mah Turnigys
    I flew till the VLC hit, just once to see what the limit was.
    It ran for 6½mins.
    To now I set the the timer for 5mins.
    I suppose I could safely run to 5½mins but I decided on 5.
    Koz
    Total Relative noob
      I run my E flight 150mA packs for 4 minutes, which gives them a good life expectancy with well over 100 flights on each pack now and still performing as new.
      Barry
      p.s. its well worth spending another £10.00 and getting the microheli MH-MSR002AC anti rotation kit from Midland Heli, which helps remove most of he slop in the flybar mechanism and vastly reduces the Toilet Bowl Effect.
      Try messing with the rudder to elev mixing on the DX6i also to remove the interaction between the right servo (looking from the back) and the rudder. Helps to remove some strange effects when straightening up after a turn.
      Barry
      Sutton Coldfield Radio Controlled Aero Club (SCRCAC for short!) Citizen 00182
      Two Blade MCP-x
      Two Blade 130x
      Red Bull 130x
      Gaui 200 V2 FBL with mini V Bar
      Trex 250SE FBL with mini V Bar and DFC head
      2 x Honeybee King 2's (now retired)
      Mini Titan E325 with Tarot DFC head and mini V Bar
      Gaui 550 CF Hurricane FBL with mini V Bar
      HK Cessna 182 Deluxe, Silver Lady and Graupner GF-15 EDF (just for relaxation)
      And a tolerant wife, what more could any man ask for?
        This eBook from Blade mSR Tips "Getting The Most Out Of Your Blade mSR" e-guide has a load of tips on different setups and ways to deprogram some of the built in mixes to get better performance once you're past the hovering stage.
        It's not free but at $7.95(£5.13) it's cheap enough for what it is.
        Koz
        Total Relative noob
          Could be a useful little book that! Might have to splash out the wonga on it!!
          Mike
          TRex 600NSP, OS55, MicroBeast
          TRex 500ESP
          Futaba 14SG Optifuel 20%
            I'm getting pretty slow forward flight compared to backwards flight.How do I fix this?
            Jim
              Well I forked out my $7.95 [or whatever it was], and having read through the booklet, have to state that there is some superb info in it regarding set up of the mSR with a DX6i and DX7. Have tried some of his recommendations and yes, they are good ones. Good value.
              http://www.rchelicopterfun.com/blade-msr-tips.html
              Mike
              TRex 500ESP
                MSR is a fantastic little heli, I have mine blinged to the eyeballs, so much fun inside flying, can fly outside on a dead calm day, use mine with a DX7 can realy set for smooth flying, or twitchy as you like.
                Realy helps with stick control for the bigger heli's.
                Tried it with a body kit on but lost the nimbleness and excitment (looked good though) was a bit heavy
                Have fun
                www.eaglercheli-club.co.uk
                home of the first guinness world record
                LOGO400, TREX250, MSR, MCPX, PHOENIX, LOVELY WIFE
                (all a bit of a handfull)
