Another progress update.
Today I finished my first gallon of fuel and at the same time I was forced to take off my training gear! With the training gear on I was just setting down to refill after my first flight of the day when one of the training legs seemed to come out ( I haven't glued them in!!). When I went over for a look I realised that it had broken out of the holder, so instead of repairing it I took them off all together. The failure was because of numerous landings on very uneven ground, so I set out a 4ft*4ft piece of plyboard as my landing pad. The heli instantly felt livelier, trying to move the tail and slide around even before takeoff but it also felt more controllable, no vibrations or anything.
I had been practising landing the heli in a particular spot on the ground before the training gear failed so I expected to be comfortable with having to set down on what seemed like a large piece of ply. Although I was scared ****less, I practised taking the heli up for a short hover of about a minute at a time to get accustomed to the lighter feeling and also to practise my set downs. Each time I was able to gently set down dead centre of the ply. The ground I am flying from is so rough that if I miss the ply and land on the soil the tail is very likely to skim the ground and shatter. It really got my heart pulsing and now all I want to do is hover a short while then set down and rest for 20 seconds and repeat.
I think before I move on to side on hovering I really need to become comfortable with the controls all over again. I'll probably spend most of the gallon of fuel practising this as I really feel that I need to be in full control at all times in this manuevre before I could justify moving on.
happy flying!!
Jonny
happy flying!!
Jonny
, you will find it takes a little while to get used to them not being on.
