Servo prob
  • Servo prob
    Hi,I've noticed that when i give full throttle My elevator servo is making a buzzing noise.How do I fix this?
    Jim
    check to see if you have any binding on the servos or you might be putting strian on the servo at the end of its travel you will need to adjust the epa in your tranny
    kasama srimok 90n
    T rex 700 Ys91sr futaba bls 452 GY520+bls 251 aerospire gov Fromeco reg
    Futaba 10c
    empty bank account
      Yes what Steve b said and also check to make sure the ball links aren't to tight on the carburetor and servo horn.
        EPA?Is this the trav adjust setting?
        Jim
          EPA = End Point Adjustment = Travel Adjust. HTH.
          M.
