A bit of Tail wag
  • A bit of Tail wag
    Hi guys,
    Is it normal for a heli to try to swing the tail anticlockwise whilst power is applied? In mine I have to overcome this tendency by applying a bit of opposite rudder as I apply power whilst trying to hover. I'm reasonably comfortable with it now and I'm able to work around it, my tail just moves a little more than I have seen on some vids. I'm guessing I need to up the gyro gain a little. I think the problem may also be that I don't have a 'proper' tail servo, just a standard cheapy. I also have the gyro centrally mounted, should I forward mount it so that it picks up the tail movement faster?
    I'm now able to hover reasonably well, another 6 or 7 tanks and i'll be getting there. I can keep the heli off the ground at a height of between 1 feet and 5 feet throughout the duration of a tank of fuel, I can also keep it within a 4-5 metre box in the same time period with some mild wind. I'll not be happy until I can close the box into about 2m and keep the height steady at between 3-5 feet. Only then will I allow myself to progress onto side on hovering.
    looking forward to the replies
    Jonny
    Hirobo Shuttle
    Hirobo Sceadu
    Black Horse Extra 330 .40
    Lots of spares
    I have just found out why my tail was moving with the heli. When I was setting up my heli initially I set the gyro gain on my radio to 65% so even though my gyro was set at 100% it was not being allowed to do its thing. I reset the gain to 80% and now the heli is a different machine altogether. If it wasn't for the slightly blustery conditions giving me sudden changes in height I think I could say that I'm now able to hover tail in.
    I'll give it another few tanks of fuel as it is before I try side on hovering.
    Hirobo Shuttle
    Hirobo Sceadu
    Lots of spares
      Glad you got it sorted out.
      What heli is it that you're flying?
      Martin
        A cheap 2nd hand size 30 shuttle, very old but flys well. I'm happy that I bought a good 2nd hand model as I don't really care what happens to it so I'm more likely to push myself on more.
        Hirobo Shuttle
        Hirobo Sceadu
        Lots of spares
          What gyro is installed? Is it the big old chunky Futaba FP-G154 as most Kyosho's seemed to have or something more modern?
          Simon (3door4x4)
          Blade 120SR, Blade 400 both bonded to my DX6i
          Kyosho Concept 30 SR-T hybrid on old 7 channel JR analogue set
          Thunder Tiger Raptor 30 V2 with TT RL53-H going into Airwolf Funkey 30 Fuselage - ongoing project!
