First Flight and it was solo!
  • First Flight and it was solo!
    Hi Guys,
    I had my first flight yesterday. I've done everything I should not have done and seem to have come out ok.
    I have very little previous experience of heli's only watching them at my local club a few years back ( I was a plane guy). But because of all the information on this forum and other forums I was able to get a good understanding of setting up a heli for the beginner, ie pitch throws etc etc.
    First task after rebuilding the head to the manufacturers spec, was to tie the heli to a pallet and fire up the engine, as the heli is 2nd hand I wasn't too sure how reliable the engine was, so I put a good 2 tanks of fuel through it while I setup the throttle and pitch curves to suit the engine. It now runs like a dream taking every drop of fuel out of the tank. I also set the tracking at this point. I had also noticed a slight vibration so I rebalanced the main blades and reset the pitch curves. I then restarted and set the tracking again! Now it runs perfectly smoothly.
    I set the heli in my back garden which has not been leveled out yet so is very bumpy and full of overgrown weeds. I then slowly started applying throttle until I could see the weight lifting and carefully watched to see which direction it was likely to lift. I spent a full tank and a half setting the trim like this. When I thought I was happy a little more throttle went on and the heli went very light on the training gear. It then started to swing a lot. I checked the trim on the rudder but could not correct this. I tried to work out what was happening blaming a very cheap gyro for this fault. I then set the gyro in reverse as I had run out of theories and this instantly cured the problem.
    It was time to fly! ish.
    I then spent a further tank and a half trying to get the heli to lift but because of the bumpy ground it would always lift in a slightly different direction. I played with the controls teaching myself what to do when the heli would move too much forward, backwards or to the side.
    The last tank I put through it I was very focused and felt much more in control as the heli was behaving as I thought it should. It was very difficult to control when it was light on the skids, but I was gaining confidence so I took the heli to about a metre off the ground. Instantly it became sooo much more comfortable to hover. I felt very comfortable like this. When I packed up for the night I was buzzing, very pleased with myself!
    So this is where I'm at with my training, I plan to practise hovering on the spot now for at least the next ten tanks before I try nose in hovering etc.
    hope the comments aren't too severe.
    regards
    Jonny
    Hirobo Shuttle
    Hirobo Sceadu
    Black Horse Extra 330 .40
    Lots of spares
    Congratulations
    One question though. If as you say, you have a local club, why not take the heli there where presumably you will have more space and some help from other members.
    Graham
    Phoenix, DX6i.
    x2
      Good on you Jonny!!!!!!!
      It was basically how I started too. Lots of gen and Lord Bob White video watching, and a fair degree of common sense.
      What heli and TX are you using?
      Mike
      TRex 600NSP, OS55, MicroBeast
      TRex 500ESP
      Futaba 14SG Optifuel 20%
        Hi guys,
        My local club is not so local as I've moved, although there is one just 12-14 miles away. I have loads of space to fly where I live, I will hopefully get a little landing patch made for the aeroplanes next year when I get round to fixing up the garden, although it would be tight. I'm very much enjoying getting back into r/c as I had to put it off for a few years. (Building house & getting married takes up a lot of time).
        The heli is a little shuttle which I picked up off the bay for £125 complete with engine, I then spent £30 on an ebay gyro (cheap crap but works well), I bought a field force 7 radio off the bay for £75 and kept my own receiver etc and bought cheap metal geared servos off the bay as well for about £5 each.. I then replaced all the ball joints on the head of the heli for piece of mind. I wouldn't have bought new as I just don't have that kind of money to spend on something I'm gonna crash shortly, so when the heli came up on the bay I had to have it at that money.
        Jonny
        Hirobo Shuttle
        Hirobo Sceadu
        Lots of spares
