how do engines work?
  • how do engines work?
    hi there all
    just wondering if someone can post me a link showing how a clutch work and how sensors work on a nitro heli?
    and also how can i build a heli without a governer if possible.
    thanks
    Er governer's never really needed to learn to fly a helicopter
    Just make a good throttle curve
    Governer's are mainly 3D items to keep the head speed you want no matter what the heli does.
    Learning and Basic aerobatics and flying use a decent throttle curve!
    Mark
    www.uavaerialservices.co.uk
    BNUCs - Operations certified
    CAA - Permit for Aerial Work
      Off topic slighty.
      Have you any good curves to hand Disc.
        Originally posted by Satch View Post
        Off topic slighty.
        no every helicopter/Engine/pipe Combo is different so you need to tweak it to your helicopter and flying style!
        Mark
          ok guys i found a finless bob video which explains some good stuff.
            wazuk'wasere/livealignlovealign strikes again!! more questions.
            3dheliflyer
              How do engines work ????
              Well they are an explosion containment device for the conversion of longditudinal motion into rotary motion !
              How do centrifugal clutches work ???
              Its a speed dependant rotary deformable disc with a high friction containment device
              Simples....
              Steve
              Steve...
              Outrage RC Field Rep
                Internal combustion engines work on the premise of 4 things happening in a given order:
                Suck, Squeeze, Bang and Blow...
                Firstly the piston moves down creating a vacuum in the cylinder which is filled by the fuel/air mixture.
                The piston then moves up, compressing the mixture.
                The mixture is ignited and the resultant force pushes the piston down an expels the exhaust gases.
                Then repeat, a lot...
                sigpicX2
                  A picture tells a thousand words and all that...
                  http://static.howstuffworks.com/gif/...-animation.gif
                  Regards, Ross
                  Raptor 50 V2 - Quick UK shizz
                  T-Rex 500 ESP that looks like it's been Tango'd!
                    That animation is for a four stroke a two stroke fires on every upwardstroke
                    And just to make it sound impressive at 18000rpm this all happens 300 times a second
                    TDR (in progress)
                    SAB Goblin 700
                    Vibe 90SG Vibe 500E
                    Kalt Baron30
                      Thats a lot of Sucking and Banging..............
                      Steve...
                        That sounds just like how a girl I used to date worked
                        Gerd
                        2 x for me
                          TDR (in progress)
                          SAB Goblin 700
                          Vibe 90SG Vibe 500E
                          Kalt Baron30
                            All of your questions can be answered here.
                            Martin
                              LOL.. i like it!!
                              Eddie
                              Velocity 90 FBL BeastX V3
                              Trex 600 LE FBL BeastX V3
                              Trex 500 EFL Pro BeastX V3
                              Fusion 50 FBL
                              VBar
                              All powered by a DX8
