bad day again
  • bad day again
    been progressing nicely on phoenix, so decided time to get some balls(or should i say remove my training balls a couple of days ago) anyway went out twice yesterday once in the mourning and again in the evening great time in the mourning but the evening !!!!!!!!!!!!!!!!!!!!!!!!!!!!! tried turning the blade 400 nose in nearly got there a couple of times but pulled out 3/4's round ,on about the five attempt got electrical interferrence (youknow what i mean some numpty on the sticks type) and down she went upside down, not too much damage pleased to report, main shaft /feather shaft and 1 servo then out came the century evolution for more play time, mid flight secound battery something went wrong lost all tail control and down she came again not too much damage and she is up flying again today having found the original problem(the tail shaft came out)
    Sounds like your making good progress but maybe you should slow down just a tad, yeah it's great to move on to the next step but maybe not at the expense of wrecking your heli's!!!
    Training gear off was a good move for sure, enjoy a bit more gentle flying time and if you want a challenge try flying in a breeze
    Keep the updates coming
    John
    http://www.youtube.com/heliclown
    Pleased To Be Awarded Four
      thanks
        As someone in the same situation of wanting to "crack" nose facing, I'd advise you to take small steps, and make sure you are absolutely sure of your inputs by using Phoenix/Sim. Be completely happy with what you are trying to do, and only then go out and try with the heli for real. More expensive when you get it wrong!! It is NOT as easy as it looks to simply do nose-in!!!
        Mike
        TRex 600NSP, OS55, MicroBeast
        TRex 500ESP
        Futaba 14SG Optifuel 20%
          i have been doing it really well(for me) on phoenix but it can't represent the fear of doing it with the real one,where as on phoenix it feels more natural. when i use the heli i start thinking about what i'm doing and then react to slow or too fast and wrong. i don't want to crash but i think the fear of crashing has been holding back, i now have to find the balance between pushing myself and keeping within my limits, hope that makes sense
            I found to crack nose in I had to fly figure 8's then gradually turn the heli more and more nose in, but kept in ff, and eventually slowed it down, just got to the point where I was just about in the hover. Pheonix helps massively, my inputs are now automatic in a nose in hover
            Sab Goblin 500
              there was a great thread last week where people gave different ideas how to crack nose in, i tried most of them ,will try that later on phoenix.thanks
                There are numerous ways to approach the Nose In Challenge but I would just add that I did it by re-attaching my training gear then lifting off with the heli Nose In, you can see the blades & heli leaning long before it gets airborne so you know what your inputs are doing!
                Just like learning your first steps when flying for the first time, little hops till you gradually see what your inputs are doing, then I started to choose a point where I'd hover to and place it down.
                This is also a massive step toward Nose In take off; you just climb gently and flick it round when your clear of the ground, a great feeling when you can get your heli doing what you want!!!
                Remember it's meant to be fun so don't rush it and enjoy
                John
                  I agree with Simon1- you almost learn it by default if it is part of a circuit, then gradually slow down the heli until you have a nose in hover. Start with lazy eights then gradually get the heli more nose in as it does the middle of the circuit.
                  Doing it this way also programs your thumbs with the escape moves.
                  Synergy N5C with 3GX on the bench
                  Trex 500 ESP FBL BeastX -soooooooooo fast
                  Trex 700 LE Beast X'd and no sticky out bits
                  Velocity 90 BeastX FBL-the love affair has begun!
                  Newton Abbot Heli CLub where the sun always shines
                    believe him, it works :P
                    Chris 'CHUNK' Newby
                    ALIGN-TREX.CO.UK team pilot
                    LYNX team pilot
                    SPARTAN team pilot
                    Dx18
                      Try not too worry too much about the bad days, it just makes the good days ..............fantastic
                      Tibbs
                      RAPTOR 30
                      MORLEY HUGHES 300
                      PLANKS
                      AURORA 9
