How important is it to use this and what is it?I bought a flasher 450 and there was a note that came with it saying to check all prebuilt parts and screws.Was going to just strip it down to kit form then rebuild it.
R48:anaerobic retainer
Blue for putting on bolt threads that you might need to undo sometime in the future (i.e. most of them). Only use on bolts that screw into metal, not into plastic.
Green for a more permanent fix, and for bearings onto shafts or bearings into holders. Again, only use on metal-to-metal contact on the whole.JR Vibe Fifty fb (YS56)
Check the screws in the tail hub. On mine, I used red loctite as the bearings were being slightly pinched when fully tight. With the red loctite, I just nipped them up till there was no play. Never came undone in all the time I had it. Fantastic little model for the price.Cheers,
Simon
Trex 700N & E
x 2
yes mate no probs !!Originally posted by supamansuper View PostSo can i just use the blue?
I've got loads of blue because I was into cars before I started helis.Kel Velocity 50 sk-720 ,Fusion 50 v-bar pro 5.2 ,Velocity 90 v-bar pro 5.2
& JR DSX11 ,Phoenix and a fridge full of bottled water
RCHA Courier Services PM for Details
www.parcelshipper.co.uk and www.impactexpress.co.uk
like steve said NOT ON plasticOriginally posted by Steve View PostBlue for putting on bolt threads that you might need to undo sometime in the future (i.e. most of them). Only use on bolts that screw into metal, not into plastic.
tut tut
adieuk
x7 eddie gold stars!
www.eaglerc.co.uk
dx7, phoenix sim
Originally posted by supamansuper View PostAm I stupid or what?
Just finished checking all the screws according to the instructions(check all prebuilt parts and screws) and just realised that the whole frame is plastic and doesn't need thread lock
lol
