B400 or flasher450
  • B400 or flasher450
    Can someone please advise me on what to buy as i cant make my mind up.I've read lots of reviews about the b400 and they all seem quite positive,havent heard much about the flasher450 but from what I've been reading everyone says the bigger the heli the more stable they are,is this right?.I'll be buying one of these in the next couple of weeks,just trying to get as much info as possible before I buy.Cheers.
    Jim
    Hmm both are good helis but I would go with the Flasher 450 as its based on Trex 450 it has less of a sloppy head due to the metal head.
    As for size the Blade 400 in bigger by one inch and both use 425 main blades. I fly a Blade 400 and love it.
    Mike, 3rd Hampton Scout Group
    Spectrum DX7
    Piper Pawnee 40
    Wot Trainer, OS 46Fx
    3D 400
    P68C Scale twin
    SRCMC
    Pround owner of an EGS
      +1 for the Flasher450.
      Don
      Heinz 450seV2 Pro
      HK 500 GT
      Phoenix
      Spektrum DX6i
        If your spending over 200.00 i would look for a second hand trex 450 sev2.
        Put a post in the wanted section here ..Im sure someone will have one for sale...the all you need is a Dx6i and your away...
        If not and you want to go for something new go the Trex 450 sport...
          Was looking at this deal for the flasher450 (Flasher 450 PE ARTF or RTF 2 4G in case T-rex 450s comparable)
          Then all I'd need to buy is the dx6.
          Jim
            You have a Stretch Blade 400 ?
            Pics please ...
            Koz
            Total Relative noob
              I would shop around maybe for a clone with a metal head and tail...
              How much is your budget??
                somewhere around £330 was going to buy the b400 with dx 6i for £289 then saw this Flasher 450 PE ARTF or RTF 2 4G in case T-rex 450s comparable for 180 and can get dx6i for 130.Do you know anything about this website?
                Jim
                  Yes they get good reviews,I have never personally use them ...However on similar threads a guy called Andy who works there is meant to be really helpful....
                  Call them up and ask them for a deal....Im sure they can help...
                  Sounds like im working for them .....Just to let you know im not
                    thanks for the help,will give them a call tomorrow.
                    Jim
                      I have got a flasher 500 and its fine no issues at all, the 450 will do you a little better than the blade and will be easier to upgrade, you can use flasher spares or align spare dependent on budget.
                      I run a dx6i on both my 500 and 450.
                      Lee
                      Crashing is in my blood, were can I get a transfusion
                      You can never have to many batts
                      Flasher 500
                      Trex 450v2
                      Dx6i
                      Purfleet Model Helicopter Club member
                        From personal experience, I would go with the Blade 400, but as I say that is only personal experience. Parts availability for either should also be your consideration, you will crash it and you will repair it, fact!!
                        I might be willing to part with mine, which has some CNC upgrades on it, upgraded tail servo etc, plus a host of spares and parts. PM me if you are interested.
                        I can't speak for the Flasher kits, but if you are looing for a 400/450, whilst some may say the TREX rules, your parts costs will be higher whilst you are crashing it regularly, and the Blade is a great heli once you set it up properly.
                        Whatever you choose, have fun, stick with it, oh and it will become addictive!!!
                        Just my opinion.
                        Gavin
                        Gavin
                        • Thunder Tiger Raptor G4 FBL - OS105 HZ-R, Bavarian Demon 3SX, MKS HBL HV Servos, Reactor HVX, Optifuel SLV 25%
                        • Thunder Tiger Raptor E720 FBL. Bavarian Demon 3X, (Under Construction)
                        • Gaui X7 - (Under Construction)
                        • Synergy N5CTT - OS55 HZ-R, Bavarian Demon 3X, (Under Construction)
                        • Gaui X5 Formula - XNova 4025-1100, Castle Talon 120HV ESC, Bavarian Demon 3X, MKS BLS Servos, Spin Black Belts, Optipower 6S 4300's
                        • KDS Agile 5.5 - XNova 4025-1100 Motor, Castle Talon 120HV ESC, Rail 556's, Optipower 6S 5000 Ultras
                        • JR Vibe 50 FBL Nitro (Retired!)
                        Optifuel * Bavarian Demon * MKS Servo Tech * Optipower
                        http://www.kaos-rc.co.uk
                          I have flown many blade 400's and set up many in my time....up to you really but a trex 450 with a metal head and tail and some good servos will be nicer to fly anytime...
                          I have owned a few blade 400's in my time,a great heli and will serve you well...also the spares are cheap...
                          But saying this the trex 450 are not really that more expensive in spares...
                          It really swings and roundabouts....
                          I hope this helps...
                            Pics please ...
                            Nope, I have a trex tail boom and belt that I was going to use on my blade 400/450 conversion after I decked it but the both the boom and belt where shorter by one inch than the Blade 400 boom and belt. So I left the Blade boom and belt on.
                            Spectrum DX7
                            Piper Pawnee 40
                            3D 400
                            P68C Scale twin
                            SRCMC
                              Don't the Main Rotor and Tail Rotor discs get awfully close with 425mm bades swinging over the normal length tail boom?
                              Koz
                              Total Relative noob
