Battery and charger advice
  • Battery and charger advice
    My head is currently spinning - I've been looking at chargers and batteries for my next "big purchase" for my Blade 400. I don't usually consider myself easily confused, but this is something else!
    Things I currently understand: S is number of cells (my current battery being 3S) and chargers can charge more or less (I've seen up to 10S!), since I'm looking long term at a 500 or 600, I'm assuming I'd be better off getting a charger that does at least 6S. Most of the chargers I've looked at require a separate 10-18V PSU, but haven't specified amps... Only occasionally have I seen wattage (around 50-200 in most cases), but it's here I come unstuck.
    I figure that the better the provided power, the larger the batteries I can charge quicker (although I need to take the C charge rating into a account for batteries, obviously). Am I right in thinking that? In other words, I'm better off getting a 200W than a 100W because it will get me back into action quicker?
    My budget is tight, so given I probably can afford in the region of £100 at most, I've been looking at the following chargers:
    Imax B6 (although I've heard bad things about these)
    Bantam BC6 (Dual Power would be my preference, as I'm expecting to charge at home more than in the field - is it worth it?)
    Bantam 301DXII
    ThunderPower TP-610C
    Remember, I'm a complete newbie, so this is only a list of what I've currently looked at. I've heard "good things" about Turnigy and AccuCell (spelling?) but I haven't been able to find UK suppliers, which is frustrating for me.
    As far as batteries are concerned, would I have to solder my own EC3s onto them? And should I aim for batteries with JST balancing plugs, given that the Eflite battery has one?
    Thanks to all those with the patience for newbies!
    Duct tape is like the Force; it has a Dark side, a Light side, and it holds the universe (and helicopters!) together.
    Understanding RC Battery Chargers
    try this link. lots of great reading for begginers, not just chargers.
    trex 550 (HC3SX)
    trex 600 nitro le (beastx)
    compass 6HV (Spirit)
    dx8.....
    its not my dog by the way.
      I should have said I have that as a bookmark - my head is still spinning even after reading that. :/
      I might be fine in 24 hours, but there is such a large choice of chargers that I'm still a little stumped. It's not so much the raw information, as the choice of chargers, namebrands I don't know, and so on.
        3S refers to the number of series connected cells, in the older times lipo's were referred to as 3S1P if they has 3 cells in series and no parrallel connected cells. Serial connected cells adds each cells voltage to the overall pack voltage, parallel cells adds to the pack capacity or mAh's
        I have an aurorra cellpro 10S and although I only have 3S1P packs I can charge 2 at a time the cellpro multi4 is also very good for up to 4S packs
        Futaba 9CP & 10CG
          as stated already if you want a charger that is very safe / balancing your packs well/ proven / easy to use / will charge,1 x 10s or 2 x 5s or 1 x 6s then the cellpro 10s is the chocie for most & has been the one back a year or two to get .
          using a 12 volt supplie at home to charge .
          many of use still use them now a good charger.
          if your looking ahead maybe something that will charge todays faster charge packs at 5c ect , then you need to be looking at mfa new offering PL8 or power lab 8 .
          Also theirs the new i charger 3010B ,BOTH CHARGERS ARE GOOD FOR 1000 WATS out with the right power supplies.
          links
          http://www.rcheliaddict.co.uk/newrep...ote=1&p=490098
          the new PL8 will be available at Aurorra ltd , soon not sure when.
          FMA Direct : Product Detail
          Battery Chargers
          also available in Europe ,but not seen it in uk yet ,but i would say it will be i reckon .
          if you do decide to go for the cellpro or PL8 say from mike at aurorra well you cant go wrong any problems & he will sort it ,with in reason of coarse.
          jim
