Problem with my Blade SR
  • Problem with my Blade SR
    Started a second practice session this evening, without warning the heli would rotate rapidly in a clockwise direction, no stick input had any effect.
    Powered down and rearmed the heli, which has had no effect.
    Looking for an explanation or is it a visit to the model shop tomorrow?
    Any help appreciated (and it was going so well!)
    Align Trex450 Sport
    Blade 130X
    DX6i
    Phoenix
    Member sigpic
    sr
    Hi, Is the tail motor working if you hold the heli at arms length and apply throttle.
    Please do this very carefully and only a small ammount of throttle will be needed.
    Keith
      Defiantly sounds like a problem with the tail rotor.
      If your going to spool it up indoors, its a good idea to take the main blades off first.
      Graham
      Phoenix, DX6i.
      x2
        I havn't spooled the heli up indoors, but did notice that the tail rotor was still functioning when I noticed the problem earlier this evening.
        Align Trex450 Sport
        Blade 130X
        DX6i
        Phoenix
        Member sigpic
          Try disconnecting the main motor, then holding the heli by the skids, throttle up until the tail rotor spins. Now twist the heli so the tail moves left and right. You should hear and feel the tail rotor speed up and slow down while doing this. This ensures the gyro is working correctly.
          When you plug the lipo in be sure not to move the heli around until the gyro has initialised.
          You could also try centring all trims and re binding the rx/tx
          Graham
          Phoenix, DX6i.
          x2
            Have you checked the grub screw on the tail blade holder mount the one that screws to the shaft I bet it's come undone and any input made by the tail servo will be usless as it won't change the pitch on the tail blades
              Might also be worth ensuring that the wires that power the motor are correctly connected. I had a similar problem with my little mSR. The tail rotor was spinning but, on pushing home the connector onto the 5-in-1 the pirouetting stopped.
              Martin
                Blade SR problems - follow up
                Hi guys many thanks for all the useful advice. The problem turned out to be faulty tail motor (now deceased). My local hobby shop (model shop Leeds ( excellent service) and Horizon Hobby, and Fast Lad))are all out of stock.
                I understand that these motors do have a problem. So it's back to the co-ax to keep the thumbs in form. Frustrating to have to wait, but at least I can still fly. And in this weather even outside.
                Thanks once again to all those who replied, your help is much appreciated.
                Align Trex450 Sport
                Blade 130X
                DX6i
                Phoenix
                Member sigpic
                  Glad you found the trouble. You getting a warranty replacement?
                  Martin
                    I bloody hope so, or there will be tantrums!!
                    No problem at Model Shop Leeds, in the past they have replaced f.o.c. When parts have failed on my co- ax. No experience of Horizon, emailed them today so waiting for the response. At the end of the day it's not megabucks, but the principle.
                    Align Trex450 Sport
                    Blade 130X
                    DX6i
                    Phoenix
                    Member sigpic
