As title says i've eventually got the time and gone out and got a copy of phoenix. Now as i'm a learner driver i only have the TX that came with my blade sr.
For the life of me i could not get my tx to perform on phoenix?!?! calibration and everything went fine the assigning of which channel does what also went fine.
But no matter what i tried when i started to try a control a heli (any heli) my throttle control just didnt input enough to get it off the floor. and my forwards and backwards stick (collective pitch?) was permanantly jammed forward however this was not having any effect on the heli ?
The roll however seemed to be working fine.
Now i have found a fix for this. All i have done is selected the EFLITE CX2 TX from the list of controllers installed, However left and right roll (cyclic?) was reversed. So to unreverse it for phoenix i simply opened up the little panel on the front and flicked the little number 2 switch ( i checked which channel it was first) and all is good now ..
I just thought i'd post this here to see if anyone else has had this problem or am i just a muppet?
Plus i found a work around so to speak if anyone else is in the same boat as me well you know
guidance to get my tx setup without changing it's settings would be nice though ..
stuart
EDIT: Sorry about my terminoligys woould appreciate it if someone could put me right on those aswell tyvm.
The roll however seemed to be working fine.Now i have found a fix for this. All i have done is selected the EFLITE CX2 TX from the list of controllers installed, However left and right roll (cyclic?) was reversed. So to unreverse it for phoenix i simply opened up the little panel on the front and flicked the little number 2 switch ( i checked which channel it was first) and all is good now ..
stuart
