450 clone
  • 450 clone
    when i fly test fly my 450 heli and im using a dx6i
    where do i need to go to increase or decearse the gyro gain ? and the hover pitch?
    thanks guys
    if you have your gyro gain plugged in to gear on your rx then you adjust the gear in travel adjust.atho you havnt said what gyro your using.
    not realy sure what you mean regarding hover pitch did you set it up with a pitch gauge?
    you set the heli using a pitch gauage for 0 pitch at midstick by adjusting links etc than you can raise or lower the total amount of pitch in your swash mix.or if you dont want a linear line say half stick hover you can change your pitch curves.
    there are some good 450 and radio set up vids on helifreak.
    450 sport
    700 le fbl
      well im using gp780 gyro
      when i said hover pitch was basically can you slow down or fasten the headspeed through the tx?
        like if the tail wags what do i have to adjust on the tx?
          If you have tail wag turn down the gyro gain
          its full of meaty goodness
          GAUI NX 7 V Bar silver line
          Align T Rex 700 F3C Flybarred
          Align T rex 600 le DFC Vbar blue line
          SAB Goblin 570 Kontronik jive + pyro
          450 pro DFC
            yea thats done with your throttle curves
            450 sport
            700 le fbl
              if its left to right its gain too high, but if it bobs up and down the head speed is too low around the point of hover.
              Sab Goblin 500
                ok. so i took the copter x to the park and pulgged in the lipo and it when i put the throttle up the esc went beep-beep-beep-beep.why? and when i pressed the rudder left it went left and got stuck there!!
                what on earth is going on i thought!
                  Is the Gyro set to Narrow Pulse?? What tail servo do you have?
                  Very Proud Owner of 1 EGS!!!!
                  _____________________
                    i dont know anything about pulse actually and i have a cer lab tail servo which worked fine when i got home!lol
                      figured it out my thro adj was 0! its shud be 100! as for the rudder getting stuc i dont knwo why
