Went out to the local field this afty, to try and solve the tail kick on my heli, tightened the belt up again, and made sure the tail blades didn't catch the deck on take off. Great !! no kick at all, so just was a belt which was a little to slack.
I hovered the battery out, about 4.30mins, then put the heli down being careful not to touch the tail blades. Changed battery, now this is a flightmax 2200, 25c, the previous batt is the same but at 20c, used the 20c just to get a feel for it again.
Spooled up the heli, the rpm sounded constant but I noticed that it seemed a bit more head spead than the previous battery, but the heli was not going anywhere?! Then all of a sudden the heli shot up in the air and I don't no whether it was my overcorrecting (because I was in the process of crapping my undies
but the heli's nose pitched up, and then I sort of just lost control, got the heli down from about 6ft, don't know how there wasn't any damage, but glad there wasn't
Don't know what caused this, took off after again and it seemd normal again, took off no trouble, tail kick back because I had come down hardish and the tail got the deck, just tighten belt and should be fine.
Im still on 35mhz and wondering whether this is an rf glitch? using fff9 tx, with a 146i rx. Not happened on other heli's with this rx though?
Maybe more powerful battery just caught me out and the soft start took a while to fully get to speed?
Cheers in advance
Cheers in advance
E.G.S.
