trex 450 sport belt tension
  • trex 450 sport belt tension
    This is my monthly daft question that I always seem I need to ask
    Just trying to tight up the belt tension on my 450 sport, problem is I don't really know how without having to take the tail all down from the frame, or can I just loosen the tail housing and pull back on it a little?
    It does seem slack, and I noticed a little vibration on the last flight, and im putting it down to this.
    Sab Goblin 500
    If it was me I would loosen the boom from the frame, pull back until the tension is right and then retighten the boom mount, remembering to re threadlock. It looks to me like the tail to the boom should be pushed all the way in.
    Trex 500 - CC450 - Blade mSR - Blade mCX - DX6i - Phoenix
      hello mate, ive got one myself and i hav to tighten mine up must times out ( i seem to hit the tail when landing ) just undo the four boom housing screws and the two on top of the stabalizer bar and pull back on boom, hold it there and tighten boom housing screws. this is how i was told to do it, also ive been told some people put a boom servo bracket at the end of the boom against the boom housing to help this problem. hope this helps
      Ronnie
      Goblin 700 - HC3sx- Konny Pyro 700-52 - konny 120hv - bls 251 - bls 451s
      Goblin 570 -demon 3sx - konny 100lv - xnova motor - Bk 7001s -BK 7005
      Boggy combat plank - wot 4 - EFX - ECt ECt lol
      FUTABA T14SG
      PMHC - A128FREEFLY - Thurrock model flying club - TTI
      GUINNESS WORLD RECORD PILOT 2012 & 2013
      GRASS ROOTS 1st PLACE, FEB 2013 ( FOR BEST CRASH LOL )
        Cheers mate, will do this now, it looks slack to me, and I was hitting the deck a little bit the last time I was out so must be that.
        Thanks again
        Sab Goblin 500
          You don't want the belt too tight, nor too slack. Loosen the boom box screws a little and pull out the boom until the tension in the belt is such that you can squeeze the belt either side of the driven pulley, but they don't touch.
          Mike
          TRex 600NSP, OS55, MicroBeast
          TRex 500ESP
          Futaba 14SG Optifuel 20%
            Too tight and you'll be causing the motor to work harder as it won't be as free running. So it'll increase the load and cause the batteries to discharge at a quicker rate. I had this problem up until Monday.
            Also I have the tail servo mount hard up against the frame as suggested in the Helituning build videos. This helps stop belt slippage during flight.
            Darryl
            Eflite Blade MSR
            Align Trex 450 Sport
            Spektrum DX6i
            BMFA Member
              The only place on the tail that needs thread lock is the tail gear casing as it's metal to metal thread contact. The four screws on the tail boom mount where it enters the frame are metal (screw) to plastic (frame) thread contact so no thread lock is required. If you do however have the servo mount bracket hard up against the frame like I do then when you loosen these off you will need to rethread lock them. But I'd just keep an eye on them and retighten after each flight until you're happy with the belt tension. If it has a bit of dried thread lock already on it, it'll be harder to work out then a clean thread imho.
              Darryl
              Eflite Blade MSR
              Spektrum DX6i
              BMFA Member
                Had a play this afty, tightened the belt up a bit last night, tried to up the gain abit but wags at anything above 35%, so thats where I am with it now.
                Bit more of a probelm is the kick of the tail which had happened yesterday and today with it? Even after I had tightened the belt, happened again today a few times during a hover about. It seems to kick about 30 degrees clockwise, very quickly and its over in a flash. Bit worrying, any ideas? im thinking its just the belt becoming slack after im landing, with the tail blades slightly touching the deck and making the tail boom slip.
                May have to hover the battery out until and not land to see if thats it, incidently the belt tension looks okay after my flights today, not too slack like it was before.
                ANY IDEAS?
                Sab Goblin 500
