phoenix & dx7
  • phoenix & dx7
    when using my dx7 with phoenix it will only work with the dx7 turned off even though the software is saying turn it on, is this normal
    sorry if it's a daft question but i am a bit puzzled!
    thats normal m8
    adieuk
    x7 eddie gold stars!
    www.eaglerc.co.uk
    dx7, phoenix sim
      thanks pal, should i make any particular adjustments in the dx7
        if you are new m8
        i would dial in about 20 to 30% expo
        until you are used to it
        adieuk
        www.eaglerc.co.uk
        dx7, phoenix sim
          well you've lost me there pal but thanks anyway
            if you go into setup menu
            and scroll down untill you get to
            D/R &EXP
            change your aile to +20 or +30%
            change your elev the same as above
            adieuk
            www.eaglerc.co.uk
            dx7, phoenix sim
              thanks i'll try that, what will that do
                You can also do it in Phoenix in the settings, this means you can set different expo for different heli's
                Expo stands for Exponential and it allows you do dull down the response of the sticks in the first part of their travel, the higher the percentage, the more dulled down over a longer stick throw it is.
                Trex 500 - CC450 - Blade mSR - Blade mCX - DX6i - Phoenix
                  thanks for a nuggit like me this is very helpful
                    no worrys mate
                    ill be on phoenix in 10 mins
                    session name eaglercheli-club
                    if you need more setups m8
                    adieuk
                    www.eaglerc.co.uk
                    dx7, phoenix sim
