Hello everybody!
I'm looking for a bit of advice regarding my LiproPlus5 battery charger. At the moment it is being powered by a 12v 4.2 amp adapter which charges and balances an 11.1v 1800mah 3 cell LiPo battery in just over an hour. I have read that ideally I should have a minimum of 10amps of power running into the charger.
The labels on both my batteries state that the charge current should not exceed 1 amp so my question is, if the maximum amp output I can use is 1 amp, what difference does it make whether I use a 4.2 amp or a 10 amp input?
If I should be using a 10amp minimum adapter, does anyone know where I can get one for less than the £28 I keep seeing online? I've already paid £40 for the charger!
I know nothing about the physics of electricity but I'm sure it will be a no-brainer to someone here!
Thanks everyone.
Jon
Thanks everyone.
Jon
