binding to a DX6i
  • binding to a DX6i
    Fellow flyers
    More numpty questions Im afraid....
    I have a Genius 450 which came RTF inc TX...anyway as I have a DX6i I put the orginal TX in a cupboard as would prefer to use the better TX so want to bind to the heli , Ive got the bind plug etc and having read 'how to' in the DX manual Im fine with that however as the heli is RTF its all wired up , do I need to take the receiver out and disconnect everything except the ECS plug prior to putting the bind plug in and running through the bind process??
    Thanks al
    Grahaml
    All the gear , no idea and no bloody time!!
    T-REX 600LE
    Velocity 50
    T-REX 500 ESP 3G FBL
    Blade MSR
    Member of:-
    Byley Model Flying Club
    Citizen 00331
    Nope, leave everything connected ready to work, set everything as you want it for defaults (Trims centred, throttle at bottom stick, switches in correct position).
    Put bind plug into Batt port (or whatever the port for your Rx) Plug the battery in, turn on the DX6i while holding the trainer switch up.
    After a few seconds the DX6i will stop binding and be ready to go, light on Rx should be solid. Unplug the bind plug, turn everything off then on again, done.
    Trex 500 - CC450 - Blade mSR - Blade mCX - DX6i - Phoenix
      Thanks Weebl .. done all that but no bind?? odd eh
      T-REX 600LE
      Velocity 50
      Blade MSR
      Member of:-
      Citizen 00331
        just a thought, what RX is in the heli, is it compatable with the DX6i as i know there are different types of 2.4ghz. i am fairly new to this myself so maybe some of the others may be able to add to this.
        proud owner of 1 EGS sigpic
          Just thinking the same as paulcobra. Is it a Spektrum Rx?
            Good suggestion...
            cannot see the make but its def not spektrum...Ive emailed the shop to ask the question...bit pants if it doesnt really
            Thanks for your help guys
            T-REX 600LE
            Velocity 50
            Blade MSR
            Member of:-
            Citizen 00331
              Originally posted by crofty View Post
              Good suggestion...
              Pretty sure non Spektrum Rx won't bind with Spektrum Tx mate
                Well, if it doesn't you can pick up an AR6100e or similar from the forum for about £25 posted. I know cos I just did it.
                Martin
                  as far as i am aware they will only bind to JR and SPEKTRUM but i am not 100%
                    oh sooo much to learn still ....doh!! can I buy off here being such a newbie?
                    T-REX 600LE
                    Velocity 50
                    Blade MSR
                    Member of:-
                    Citizen 00331
                      You can buy - you can't sell..
                      Martin
                        Hmmm. well popped out today and brought a Spektrum AR6100 receiver , fitted it , ran through the bind process as above ...light on receiver is now solid BUT on reconnection nothing happens although i can hear the lecy buzz through the heli !?! am I being dumb!?!?
                        T-REX 600LE
                        Velocity 50
                        Blade MSR
                        Member of:-
                        Citizen 00331
                          My order above was slightly wrong, bind plug should be left in until battery is disconnected. Although I don't think it makes a difference really?
                            Its ok ..thanks for response anyway ..fixed it , had the servo connectors in wrong way round!!! oops
                            Maiden flight tomorrow all being well
                            any suggestions on TX set up anyone(difficult I know as its not a popular heli)?
                            T-REX 600LE
                            Velocity 50
                            Blade MSR
                            Member of:-
                            Citizen 00331
