Mini Titan Belt
  • Mini Titan Belt
    I have got a titan and the belt will not stop slipping ?
    I have changed the belt and the new one still slips, it seams to slip only on the front gear. the belt is tight and is OK for about 20 seconds then starts to slip?
    The ajustment as not changed (I marked the boom to check)
    It's more than likely me doing something wrong
    Thanks for any help
    Darran
    The best a TDR HC3sx Kontronik 120HV
    Logo 550SX Vbar Kontronik 100LV
    the basher and crasher Trex500 mini Vbar
    PMHC + TMFC
    If you have the original plastic front gear its probably slipping on the shaft,if it is that I would go for the metal upgrade.
    http://www.fast-lad.co.uk/store/pv08...25-p-1371.html
    Martin
    x2
    Rave 450
    Trex 250se
    DX7se
      Hi have just held the belt gear and I am unable to turn the drive gear that's right I think, is it ?
      Darran
      PMHC + TMFC
        You may have to remove the tailboom and remove the gear and twist the two gears with your fingers.
        You said it is ok for about twenty seconds before it starts to slip, the gear may be tight when its cold but as it starts to slip it may warm up and start slipping more,
        Hope that makes sense, this happened on mine a couple of years ago because the belt sprocket was slipping on the shaft, it started off as 'kicks' and flicks from the tail when I was flying.
        Martin
        x2
        Rave 450
        Trex 250se
        DX7se
          Thanks I think I will be buying a new front gear from fast lad
          Darran
          PMHC + TMFC
            While you have got it apart I would fit the tailshaft upgrade too as the same thing can happen to that one too.
            Fast Lad Performance
            Martin
            x2
            Rave 450
            Trex 250se
            DX7se
