Trex 450 sport gyro mounting
  • Trex 450 sport gyro mounting
    Could anyone tell me please where I can put my 401 gyro on my sport? tried the gyro plate that comes with heli, but the gyro is too big and cannot fit under boom, my rx is in the base plate, and due to the wires coming from the servo's thats looks about the only place it can go.
    Maybe I can put the rx on the gyro plate plate?, and then the gyro in the base plate? Will this be okay though would seem very close to the motor, just a few cm off it?
    Scratching my head a bit with this one
    simon
    Sab Goblin 500
    Out of interest, what gyro are you using?
    Martin
      401 maybe
      Retired
        yep 401
        simon
        Sab Goblin 500
          er........erm.........a 401 Martin...........
          Mike
          TRex 600NSP, OS55, MicroBeast
          TRex 500ESP
          Futaba 14SG Optifuel 20%
            A 401 ya say?
            I must admit, I found putting the electronics in my SEv2 a bit tricky. Is there nowhere on the underside of the tail boom mount that you can put it, as is the case on the V2? You can see my 401 in this pic:
            Martin
              As Martin said, there is an issue with lack of space in the 450 sport frame. I'd try your latter suggestion of gyro bottom plate and rx mid rear shelf. I'd be more worried by my gyro's proximity to the ESC - where have you mounted that?
              Mike
              TRex 500ESP
                The ESC is under the battery tray, I have just looked again, I could put the rx on the gyro mounting tray, and the gyro underneath? Don't no if the C of G will be affected the gp750 looks a smaller gyro and have noticed that some of you have that underneath the gyro tray.
                thanks
                simon
                Sab Goblin 500
                  Hi Simon,
                  I mounted the gyro on the bottom plate which worked well. The rx was mounted just in front of the gyro also on the bottom plate.
                  The gyro plate is used for the align gyro which is a lot smaller.
                  I have one for sale if you like align 750 that is
                  Cheers Matt
                    Hi Matt, the best I can do on the gp 750 is a swap for the 401 I'm still on 35mhz rx, its the futaba 146i rx, and it looks a bit tight to get all of the servo leads plugged in, I can do it, but its too far back in the base plate, so no where for the gyro to go. Will have a try at getting it further forward and see if I can sit the gyro behind .
                    Thanks for sending those couple of bits by the way forgot to PM you.
                    simon
                    Sab Goblin 500
                      You need to sell it for scrap and fit a Quark then there is loads a space....
                      Steve
                      Steve...
                      Outrage RC Field Rep
                        Steve
                        That brutal Tried everyway but the right way at the min, looks like the 401 is going to be too big doesn't fit right under the gyro tray, or on the base plate, and doesn't fit under the tail boom....im stumped..
                        Sab Goblin 500
                          Here is the layout that I use on my Sport and seems to make the heli fairly well balanced.
                          Darryl
                          Eflite Blade MSR
                          Align Trex 450 Sport
                          Spektrum DX6i
                          BMFA Member
                            Pic of my 450 sport with 401 fitted-space is a bit tight but it still fits,,,
                            Sab Goblin 570
                            Sab Goblin 500
                            500E Pro dfc
                            450 Pro dfc
                            Blade 300X
                            DX9
                              Pick up a crap gyro for peanuts, sell the 401 for £50-£60.
                              Do a Px and get 30% off a Quark (if that offer is still on)
                              x 3
