I ordered a set of carbons recently that were supposed to be the correct type but when they arrived I found that the root attachment isn't as thick as the originals and there's a big gap in the blade grips. Would they be ok with some sort of shims top and bottom or should I not use them?
Carbon Blades
i hve bought some from revolution models before for my blade 400
CFC washers (4) Ref: 3358
Price: £0.85 (£0.98 Including VAT at 15%)
Due to the supply problem with the original Blade 400 main blades we have manufactured some CFC washers so that the vast majority of Trex 450, Twister Storm, GL450 main blades can be used. These blades have a 5mm root whereas the Blade 400 is 6mm
cut some out of plastic milk bottles(not the glass ones though
