futaba 7CAP questions
  • futaba 7CAP questions
    1. Can you switch the damned beep off while programming?
    2. when I copy a model it doesn't copy everything. flight modes came out inhibited on the copy, and I think it didn't copy the pitch curves. Is that right? Surely copy the model should be just that, and go fly!
    3. some things don't take effect until you switch off and on (it doesn't actually change from PCM to PPM on the screen until you switch off and on). Is that right?
    1. No, not that I know (loud isn't it - unless it's when your flying - then it isn't loud enough)
    2. Not sure about this one, I'll have a play...
    3. PCM to PPM or the other way around - Yes, you do have to switch off then on again.
    Cheers, Lee.
    Proud recipient of an EGS
      1...yes, bloody annoying!! I can't find a way around the bleep either.
      2... not sure, haven't tried it, but will test that.
      3... that is correct. The manual says that you have to make the deliberate effort to switch it off, then on, to change from PPM to PCM or vice versa. This is to stop accidental switching
      David
      Happy Landings.
      David
      Raptor 50. OS50
      Mcpx
      Blade 130x
      Goblin 500
        thanks guys!
