Walkera 5g6-1 - Whistling
  • Walkera 5g6-1 - Whistling
    Hello
    This is my 1st heli which i opened last night and after the contoller syncs with the heli it ommits a whistling sound from the right handside.
    Is this normal?
    Hmmm from the heli or the tx?
    If the heli not sure if this normal unless the motor is trying to turn or it could be the rx/bec.
    !Update!...
    This is a known problem and it seems the noise comes from the motors when the tx throttle is either at min or very low. This can it seems damage the motors and in some cases burn out the rx/bec.
    Check the last post on page 2 in this link:
    http://www.rcgroups.com/forums/showt...=734432&page=2
    Mike, 3rd Hampton Scout Group
    Spectrum DX7
    Piper Pawnee 40
    Wot Trainer, OS 46Fx
    3D 400
    P68C Scale twin
    SRCMC
    Pround owner of an EGS
      My 4g3 did it until spooled up as my mates did think its just the ESC doing its bit
      hope this helps Jim
      Cheers all Jim
      Beam e4 I LOVE IT
      Trex 450 Airwolf in progress
      walkera 4g3(complete pants
      Blade MSR Quality
      speccy dx6i
      PROUD OWNER OF 1 EGS
      If it flys fly it if it doesnt fly drink it
        !Update!...
        Walkera 5G6-1 vs 4#3 - Page 2 - RC Groups
        Thanks for your replys i had a look at that and then another good look at the heli, im pretty certain that the noise is coming from the black box above the battery which the tail is connected too (servos i think!) It certain starts as soon as the heli connects and the blue swash plate adjusts, this is always slanted so could that be caused by the servo slightly running? If i give a small amount of throttle i can hear the motors start to whistle.
        If it is the sevo is it just a case of them being faulty or is there something i can adjust?
          Hmmmm Not sure servos give out a buzz rather than a whistle but I could be wrong as I've never had one of these helis. Does it go when you spool up? It just be what beerdeor suggested?
          Spectrum DX7
          Piper Pawnee 40
          3D 400
          P68C Scale twin
          SRCMC
            Yep, the "Walkera whine" is perfectly normal. It's coming from the servos. Don't worry about it.
            Neil H: Certified compatible.
              Can't really tell over the noise of the rotors.
              Normal? Dam thats quite loud, is it pot luck? Surely they all can't do it?
              Am i right in assuming the swash plate should be level?
