Lipos and Balance Charger
  • Lipos and Balance Charger
    Well I'm new to these fandangled balance chargers and have a question to ask in regards to parameters to use. I'm using the Sigma II EQ charger as recommended by a few of the members here as it only cost £60 and has a built in psu so can run off mains without having to lug around a PSU (for meets we should look at running one big PSU , bags not being the guy bringing it though).
    Anyway on to the point, I'm running at the moment a Blade400 and Trex450 Sport so using 11.1V 3S batteries around the 2100mAh mark. I've set the voltage to 11.1V and number of cells to 3S. For the current setting would I'm taking I should input 2.1A (2100mA). Is this correct?
    Darryl
    Eflite Blade MSR
    Align Trex 450 Sport
    Spektrum DX6i
    BMFA Member
    Yep
    Phil
      Phil, short and sweet and to the point
      Darryl
      Eflite Blade MSR
      Spektrum DX6i
      BMFA Member
        I have an Align battery that is 2150mAh would you set it to 2.1A or 2.2A as the increments only go in .1 of an amp.
        Darryl
        Eflite Blade MSR
        Spektrum DX6i
        BMFA Member
          Neither will hurt it, 2.2 will go marginally faster.
          | 3D Championship
            Cheers Rob, my align lipo just charged in about 22min said discharge capacity 704/705?
            Darryl
            Eflite Blade MSR
            Spektrum DX6i
            BMFA Member
              I guess that's the mAh the charger put back into the pack?
              It would stack up with the time it took to charge the pack, so maybe?
              Usually, a full charge at 1C will take 1 hour.
              | 3D Championship
                I guess for storage the batteries have partial charge. Oh and what is this info that came with the Align Lipo about normally you charge at 1C so 2150/1C or 1000 = 2.15A. They then go on to say that Align recommends charging at 0.5C so 2150/0.5C or 500 = 4.3A??? Is that correct, does anybody actually do that or do they just charge at 1C?
                Darryl
                Eflite Blade MSR
                Spektrum DX6i
                BMFA Member
                  I have two 2500 and one 2100 and the guy i bought mine off said charge the 2500 at 5amp and the 2100 at 4.2 amp
                    That's 2c! You might want to verify the lipo brand having said that, Today's lipo tech is so advance, thus it should be fine!
                      t43er, you sure as i thought 0.5C = 500, 1C = 1000, 2C = 2000. So 2500/500 = 5A, and 2100/500 = 4.2A. I'm most likely wrong though.
                      Darryl
                      Eflite Blade MSR
                      Spektrum DX6i
                      BMFA Member
                        No, it depends on the value of C where C is the capacity of the battery in question in mAh.
                        Trex 500XT Spektrum DX7/9 Trex 250 550X
                          1c=1/1000th not 1000 so to charge a 2200mah it would be 2.2A
                            Not at all. 1C = 1 x the capacity of the battery whatever it may be. 2200mAh = 2.2A however.
                              oi im legendary with my understanding of electrics!!!! so you may well be right,infact you probably are
                              thats how i work it out capacity of the battery divide by 1/1000
