Should I lube anything on my mCX
  • Should I lube anything on my mCX
    was jsut wondering if I should put some sort of lube on any of the parts on my mCX like main gear ??
    Only ask as I dont recall see anything about this in the manual?? or seeing it mention on youtube vids on hot to fix mCX/mSR
    https://www.benchtech.co.uk/
    Blade 400 3D
    Blade MCX
    Phoenix
    DX6i
    Hi no you should be fine the gears are ment to run dry, possibly just a dot on the main shaft.
    Alex
    Innovation RC Blog
    Innovation-Rc on eBay
    www.heliharry.co.uk
    www.robochallenge.co.uk
    500 ESP. Ely Q Comp, KASAMA'd 600
      Oh ok cool
      Thanks for the help much appreciated!
      Blade 400 3D
      Blade MCX
      Phoenix
      DX6i
        Dust and grit would stick to exposed grease and lead to more wear than without. I guess the plastics they use are self lubricating like delrin etc.
        Futaba 9CP & 10CG
