Hi all, just a quick question as I found this a bit odd but the Century manual says to join the engine and muffler together using ThreadLock Normal (not perm). It doesn't mention at all about using a gasket. Is this method alright for mounting a muffler to an engine as I would of thought it would of needed a gasket and gasket glue to attach it. Any help would be appreaciated.
Attaching Engine + Muffler
I have an Alu gasket on my 50 hyper in the Raptor and used to use a smear of silicone with my old OS32 - both work fine as does not using one at all (on all my planks).Rob
Futaba 9CP & 10CG
Lol at using clear silicone sealant. Reminds me of some of the old bangers I've seen
Ok will try running without as I don't have one and the engine might be shot anyway. Afaik it won't cause any damage, just run noisy if there isn't a good seal between the mounting flange right?Darryl
Eflite Blade MSR
Align Trex 450 Sport
Spektrum DX6i
BMFA Member
x 3
