Throttle full power but no lift
  • Throttle full power but no lift
    Hi i have just bought a honeybee fp v2. Just had my first attempt at flying, but at full power its not lifting off the ground? Any ideas anyone please.
    Thanks. Sorry to sound dumb but can you adjust pitch as its a fixed pitch. Sorry, but if so how would i do it.
      Sounds like its two things for me, your battery is goosed, or you have got no pitch,.
      I have an old century hummingbird fp, and to increase the pitch on that you could heat where the main blades attach to the head up with a hair dryer, and then twist the blades, to increase the angle of the main blades.
      hope this helps
      Sab Goblin 500
        If the heli is new then send it back.
        If it was bought second hand, I would suspect either the battery or the main motor is duff
        Graham
        Phoenix, DX6i.
        x2
          Good point, yes could well be motor aswell
          Sab Goblin 500
            apart from the above thoughts :-
            check the motor connections to the controller :- you could have the main motor connector reversed rotating the blades in reverse. Also make sure the main and tail motors are on the right connectors
            450 Sport * 2
            600LE on the way
              When i had this problem with the hb it was the blades that needed warming up then twisting to get it to lift
                hmm could it also be the pinion on the motor is loose, tight enuff to turn the blades but when it gets any press from the light it starts slipping.
                  hi got one of these myself ,its the stock lipo it only has an output of 10c current draw which is not enough to lift of properaly. Upgrade lipo to 15c output or above and you will think its a diferent heli.
                  New to this and wish i could fly
