Futaba FF7 ratchet
  • Futaba FF7 ratchet
    On the new FF7CAP is it a simple matter to change the ratchet into a smooth friction for collective.
    Can't tell as its under the tree...
    No...can't find a seller of smooth ratchets, what I did was take out the metal spring that makes the ratchet, bend it "round" with a pair of pliers and put it back. Works fine. basically, take out the "notch" on the ratchet. smooth it & put it back. Same bit of metal. But different shape.
    Watch it though....when you replace the back of the Tx, make sure the terminals for the Tx battery (on the mother board) are not bent, they come through a very small slot in the back case & can get bent easily./
    David
    Happy Landings.
    David
    Raptor 50. OS50
    Mcpx
    Blade 130x
    Goblin 500
      On my 9C I just took some of the power off the spring by bending it back slightly and putting a tiny dob of grease on the rachet - that made it almost entirely smooth but some people run a bit of wet & dry 400 over the rachet too to take the tops off the plastic teeth
      John
        Yeh, same thing really. Either take the teeth off the wheel, or take the notch off the ratchet. Either.
        The standard notch is pants though
        David
        Happy Landings.
        David
        Raptor 50. OS50
        Mcpx
        Blade 130x
        Goblin 500
          er doesn't the 9c come with an optional flat rachet ready for the Helicopter user if you wish to change it?
          Mark
          www.uavaerialservices.co.uk
          BNUCs - Operations certified
          CAA - Permit for Aerial Work
            I saw one on the internet where the guy put some fuel tube over the spring so it still presents friction but takes away the ratchet effect..
            Raptor 50v3 Titan, OS50 Hyper, Futaba S3152 Servos, Futaba 401 Gyro, CSM Revlock 10, Futaba T9CP Super TX.
            GT450s Flexwing Microlight G-MASI.
            "For once you have tasted flight you will walk the earth with your eyes turned skywards, for there you have been and there you will long to return." Leonardo da Vinci
              Probably. No thought process with these manufacturers
              All these work. The fuel pipe idea is worth a look at. Having said that, when I flattened out my ratchet it too worked ..free
              David
              Happy Landings.
              David
              Raptor 50. OS50
              Mcpx
              Blade 130x
              Goblin 500
                fuel tube works I put a spot of super glue on inside tube just incase, but you still have to bend out quite far to get a nice feel.
                Good thing is if you want to sell up at a later stage, you only have to cut tube and can sell to anyone!
                www.evorc.com
                Beam E4 Specialists with a complete stock.
                Synergy, Rave, Align, ElyQ We stock kits, spares and SE upgrades.
                See web for many other top brands.
                Feel free to call just for a chat.
                  i flatten the ratchet out then take the teeth off the cam with sandpaper. then you tweek the spring tab to give just the right amount of braking.
                  Ade
                  www.accurc.com
                  adrian@accurc.com
                  This is an apple free zone
