What's this for?
  • What's this for?
    Having a rummage in me flight box today n I came across this little gadget
    Can only assume it’s a heli tool of some sort but what’s it for?
    Top unscrews but nothing else?
    Anyone
    Cheers Wyn
    Rockin in the RWD world
    It's a gordknowswhatfer designed to spangle a whatsit to a swashplank....everyone knows that
    I'm bored
    David
    Happy Landings.
    David
    Raptor 50. OS50
    Mcpx
    Blade 130x
    Goblin 500
      looks like a piston lock?
        its something that is used to do serious damage to engines.
        you take the glow plug out, put that in its place then tighten the fan onto the crank.
        the tool then punches a nice hole in the top of your piston.
        bin it before your tempted to use it!
        Ade
        www.accurc.com
        adrian@accurc.com
        This is an apple free zone
          I knew that really
          Happy Landings.
          David
          Raptor 50. OS50
          Mcpx
          Blade 130x
          Goblin 500
            Its an enginefuccerupper tool
            avoid using
              yer its used to lock up your engine(maybe permanently ) to screw on the fan and clutch, like ade said good for buggering your engine not much else
              the best thing is to eject it, if you need to lock the engine up for that purpose, get a proper crank locking tool where you take the backplate off, second to that a soft ish (not brittle) tooth brush handle in the intake(you have to take the carb off)
              cheers Lee
                I think some one at MDS designed them, Only for use on Mds engines as you cant make them any worse than they are direct from the box
                Gaza07
                Trex 500esp 6s Beast-X V3
                Trex 600esp 12s Beast-X V3
                A few Multi Rotors
                  I see
                  Glad I found out b4 I did ever try use it then.
                  N there was me thinking it was some sort of mini ball joint greaser or fancy heli torch lol
                  Best I send it as a crimbo pressie to me best m8 lol
                  Cheers Wyn
                    my dentist has tools that look like that
                    Clones are bad
                    .... that includes Align ones
                      "you take the glow plug out, put that in its place then tighten the fan onto the crank."
                      could of sworn that that was what i said?? LOL
                        Reminds me, how was the dentist the other week Thomas
                        Phil
                          avoid using
                          Lol (Best one)
                            I've been using a piston locking tool similar to this for years on 30 to 90 sized motors and never damaged an engine yet.
                            But, I can see how it's far from ideal so am going to invest in a couple of crank locking tools anyway.
                            JR Vibe Fifty fb (YS56)
                              They are not brilliant because they put stress on every critical point on your engine rather than a toothbrush down the crank hole which only loads the front part of the crank which its designed for
