Help Before I Loose The Will To Live - Gyro Problems
  • Help Before I Loose The Will To Live - Gyro Problems
    I have a Hummingbird 3d Pro which I have built up and everything seems to be working mechanically/electrically OK with the exception of the bl**dy gyro (a Century Heading Hold gyro) which came with the kit.
    When I spin up, the helecopter spins like a top.
    I have adjusted the gain to 80%, still spins. Have reversed the servo - still spins.
    I have Futaba 6EXH radio
    Channel 5 is connected to gyro
    Is the gyro knackered?
    Is it me?
    Any thoughts on set-ups.
    PS - have been back to shop today who set up the gyro but didn't test. When I got home and tested it - STILL SPINNING LIKE A TOP
    Hi there, you have tried reversing the servo have you tried reversing the gyro, if there is no jumper or switch or whatever you may need to turn the gyro around 180 degrees. I'm not familiar with your gyro (or many gyros come to think of it) so dont know anything more sorry.
    Col.
      Hi
      Just a correction to Cols post, think he meant to say flip the gyro over by 180 degrees so it is upside down compared to how it is now.
      Turning it around 180 Degrees won't make any differnce!
      Bob J
        To test its not in need of reversing try the following
        Put a left rudder command in and check to see that the tailblades would indeed give a left yaw..ie normally lower blade leading edge goes to the right
        Make a note of which way the servo arm moves to give that left command
        Now twist the heli slowly to the right and check to see that the servo arm gives the same left command,if it goes the opposite way the gyro needs reversing by turning it upside down or rightway up depending on which way it is at the moment
          Er
          its a white GWS gyro isnt it...
          Er your not going to like this....
          buy a Futaba 240 there 49 pounds I think far better
          as for the GWS white thing...
          Mark
          www.uavaerialservices.co.uk
          BNUCs - Operations certified
          CAA - Permit for Aerial Work
            place on a hard surface.
            hit repeatidly with a lump hammer.
            feed to dog.
            Ade
            www.accurc.com
            adrian@accurc.com
            This is an apple free zone
              feed to dog.
              i confirm and agree
              cheers Lee
                No ,stick it on Ebay,someone will buy it
                  Originally posted by BobJ View Post
                  Hi
                  Bob J
                  Oppps that what i meant should have been clearer. Sorry
                  Col.
                    feed to dog.
                    Ade
                    Please clarify:
                    Is this Head - Wife - Helicopter or Gyro ?
                    PS Does sound like Gyro (rather than servo) is reversed - you have checked blades on right way round - no slop in tail rotor drive train
                    John
                      definitely helli and gyro.
                      Wife depends on what time of the month it is and how long you want to get trapped in a place with lots of men of questionable ethics
                      however using this treatment could either be used last so you dont have to spend time in the nasty sounding place or you could do it first to save the effort of doing the other 2 as once your finished with this head treatment the rest wont matter :-)
                      Ade
                      www.accurc.com
                      adrian@accurc.com
                        It might be me or another member so don't bother.
                          Houses of parliament???
                          LOL
                          | 3D Championship
