What is a cyclock, what is it used for, what does it do , how much is one etc... Cheers.
cyclock?
cyclock?
Henseleit TDR
V-Bar x2
SAB Goblin 700 V-Bar
T-Rex 700e DFC V-Bar
Synergy N7 V-Bar OS105 HZ-R
Synergy E7se V-Bar
Synergy N5c FBL V-Bar
Gaui NX7 V-Bar YS91 Tareq SRX
T-Rex 550 E FBL V-Bar
Gaui NX4 V-Bar
Tags: None
On blackberry so will be a bit short but basically it is used to do ccpm mixing on board and therefore bypass any mixing latency in tx ccpm mixing. They work well on the 600 . They can also nb used on. A csm flybarless system with 3 720'4,
Hope this helps
They are about 40 quid.
It does many things, but you need also the csm lead and a pc to do them.
Rather than use your tx ccpm program you set your tx like a raptor (separate elev, aileron and pitch) and plug those rx channels into the bikelock and it does the ccpm mix.
Yuo can program a virtual cyclic ring (as you stir the stick you get a constant max swash tilt, not a bit more with the stick in the corner).
you can make adjustments to the phase - change the roll axis so it is a little off parallel with the tail boom, or more importantly correct it so it is parallel.
you can compensate for thenon linearity of the servo output discs
If using a revlock30 you can make it automatically back off on the collective to stop it bogging (collective management).
It enables the use of two gyros to drive a csm flybarless system.
As it takes the pitch channel and sends it to the three swas servos it does so all at the same time whereas from the rx the three channels are sent in turn, one after the other with jr, but the first two, then a wait for throttle and rudder and gyro gain, then the third with futaba. some people reckon with futaba they can see the swash tip a bit when they move collective.
It probably does lots of other things too.Last edited by moyesboy; 13-10-2009, 10:49 PM.www.heli-extreme.co.uk a good club in south Sheffield
It takes control of the cyclic mixing away from the TX allowing you to eliminate (mostly) any interactions between Ail/Elev/Pitch.
It also allows you to adjust the phasing electronically and add a virtual cyclic ring which stops the cyclics binding when the sticks go to the corners.
Edit: Too damn slow again...Ian
Knight 3D
Velocity 50
think most have forgot to add that as you are running 140+ on endpoints you get full resolution of the servo travel which makes the model feel a hell of alot crisper , plus you can dial out any interaction between servos ... I love mine and it feels like flying a different model even though it flew wel before I had a cycloc
Thanks guys for your input to this. Since starting this thread i found a great write up on Real Rapters site as well.
Thomas, how much are you asking for yours mate? PM me if you wish.
Once again, thanks for all your inputs, cheers, Rob.
Henseleit TDR
V-Bar x2
Synergy E7se V-Bar
Gaui NX4 V-Bar
