What else do i need
  • What else do i need
    Right,
    Further on from my previous posts.
    Am looking to get a Nitro 50size Heli in the new year (if not before LOL)
    Am new to Nitro Helis, so am making a list of the stuff i will need to buy, but not really knowing what i need i have come up with the following...
    Heli
    Engine
    Servos
    Gyro
    Receiver
    Tail servo
    Voltage regulator
    Not going to get a governor to start with.
    Have a 6v receiver pack i can put in.
    Anything else i have missed, that is glaringly obvious??
    CHeers
    Joe
    Very Proud Owner of 1 EGS!!!!
    _____________________
    You'll be needing a pipe, also a set of blades (most kits don't include them).
    Starter, fuel pump, glow stick...
    If you've got a 6v RX pack already you don't need a regulator. Reg. is only need for use with lipo packs because they put out 7.4v which most servos can't handle.
    Ian
    Knight 3D
    Velocity 50
      Pipe? Thought that came with the engine
      Blades ok cool
      Starter, Fuel Pump and glow i have as i alread fly planks .
      Thanks re the voltage regulator, i will put that money into the blades
        Aswell as everything else mentioned, you'll likely need a starter shaft, preferably with a one way bearing.
        Current kit
        Evo 50
        T-rex 500FG night setup.
        T-rex 700N pro
        T-rex 450 pro
        10CP
        Frankenstarter (dynatron)
          Thanks, forgot about that one LOL.
            fuel and starter exp... I have a Starter i got for free i'll be getting a Align starter in a few days, i'll pass it on to you when my align starter comes
            I left the hobby 3 years ago and discovered Women.
            I wish I never left.
              you have a pm mate
              cheers liam
              Taort 450 pro v2 fbl
              mz18
              proud owner of 2 egs
              sponsored by :
              KBDD International Pilot
                Depending on the tail servo you might need a step down to reduce the 6v to 5v for the tail servo (you'll need one for a 9254 but not for an align 620).
                A remote glow extension is a must so you can start he heli with the canopy on. May or may not be in the kit.
                  Err guys what about erm the fuel itself????
                  www.lincsheli.com
                    Alternatively, you could get a couple 3700mah 4.8 volt NiMh packs for about £10 each and not worry about any servos that cannot handle 6volts.
                    (you don't have to have more than one, but they are not expensive so with a couple you could fly with one and still have another charged and ready to go)
                    On the starting wand, if you don't need one with it's own one way bearing, (for example Raptors have their own one-way on the starting lug) I have a few extra ones I'll happily send you one for the cost of postage.
                      i said fuel before... I would go for 20% optifuel
                        Originally posted by sonofdelboy View Post
                        you have a pm mate
                        cheers liam
                        pm replied Liam
                        Joe
                          So you did!!!!
                          www.lincsheli.com
                            recommended:
                            A crankshaft locking tool. It's very handy when putting the fan to the motor, and even handier when taking it apart. Price < 10 pounds at most shops.
                            A silicon tube for the muffler (where the exhaust gases come out, not talking about the pressure line for the tank). If the heli ever hot-starts, squeeze it shut and the engine dies within a fraction of a second.
                            A 2nd hand 450-size 3s or 4s LiPo for the starter.
                              pm joe
                              mz18
                              sponsored by :
