Blade 400 - Greasing and Lubrication
    ive just stripped out mine and it has two of the shims per side also a spare head i have is the same . the step in the washer goes towards the rubber damper
    sorry its a bit blurred it was done quicly
    You sure about that Boggy? As How to Repair and fix Your Blade 400 Helicopter
    says that the flat side is suppose to face the rubber o-ring and the ridged side outwards. Makes sense if you ask me aswell as they said the stepped/ridged side would wear the o-ring.
    Darryl
    Eflite Blade MSR
    Align Trex 450 Sport
    Spektrum DX6i
    BMFA Member
      its the way ive always had mine. and im on my second dampers in about 18 months of flying it!! so thats nearly 3 whole flights
        Grant have you got any input on the orientation of the step washer that sits next to the o-ring. Which way do you have the step facing?
        Darryl
        Eflite Blade MSR
        Spektrum DX6i
        BMFA Member
          Just uploading the pictures now mate.
          Proud owner of 2 Eddie Gold Stars!
            The first picture is where i have taken the feathering shaft bolt out that has a small washer on.
            Then in the second picture I screwed an old flybar into where the bolt goes so that I could slide all the pieces along the flybar without losing anything
            The third picture shows the old flybar screwed into where the feathering shaft bolt was.
            The fourth picture shows the blade grip and what goes on the outside of it,There is the bearing a very thin washer,then the thrust bearing which consists of the two bigger washers with the bearing cap (gold) in the middle of them.
            The fifth picture shows what goes after the rotor head,before the blade grip.There is the rubber o-ring (damper) then four shims,a washer then a bearing.
            Hope this helps.
            Cheers Grant.
              It does so yours has the 4x 3mm shims next to the o-ring and then the step washer after that? Which way is your step washer facing?
              Darryl
              Eflite Blade MSR
              Spektrum DX6i
              BMFA Member
                The step always faces the bearing.
                Dan
                Blade MSR
                Blade MCPX
                Blade 400
                Align 450 Pro
                  Dan, that is what I thought but I'm sure Boggy said that his is facing the o-ring.
                  Dan do you know anything about the shims. Should it be bearing, step washer, 4 x 3mm (inner diam) shims, o-ring?
                  Update:
                  Will you be going to the Calshot meet by any chance? Will bring it along there and you can have a look over it and a fly. Trying to get it back up together and out for a flight in a minute if I can get it done before sunset.
                  Darryl
                  Eflite Blade MSR
                  Spektrum DX6i
                  BMFA Member
                    Ok technical reason for the step washer.
                    The step washer is there to ensure only the center part of the bearing is in mechanical contact with the feathering spindle. The outside must stay in contact with the blade grip only. So the step side must always face the bearing this ensures the contact area is the balls inside the bearing and not the bearing shell.
                    The shims behind the step washer ensure the corect preload pressure on the bearing to make it work and remove manufacturing tolerances.
                    Steve
                    (never onwed a blade by the way)
                    Steve...
                    Outrage RC Field Rep
                    • #25
                      Cheers steve. I'm pretty sure my Century Hawk Pro doesn't have any shims, don't even remember o-rings when I was stripping either. Might of been a different shape cylindrical instead of toroid.
                      Darryl
                      Eflite Blade MSR
                      Spektrum DX6i
                      BMFA Member
                      • #26
                        Update:
                        Well that is the way I have put it back together, that was the way it first come apart. But I have just been looking at the exploded diagram in the back of the manual and bogey seems to be right. Before I joined this web site I was with helifreak and everyone puts the head together the way mine is. To be honest I can’t really see that it would make a difference which side of the blade grip you put them as long as there is the same amount of shims. This will be something I will be looking into more.
                        I will be at Calshot on the 7th then I’ll have a look.
                        Good luck getting it back together for another fly.
                        Dan
                        Blade MSR
                        Blade MCPX
                        Blade 400
                        Align 450 Pro
                        • #27
                          The 7th, there is a meet on the 7th? I thought it was the 9th???
                          The exploded diagram doesn't show enough detail to show which direction the step washer is facing.
                          Darryl
                          Eflite Blade MSR
                          Spektrum DX6i
                          BMFA Member
                          • #28
                            LOL, my bad. it is the 9th!!!!!!!!!!!!!!!!!
                            Dan
                            Blade MSR
                            Blade MCPX
                            Blade 400
                            Align 450 Pro
                            • #29
                              What pitch settings would you recommend. From the factory mine seem to be around the following:
                              +12-14, +4-5, -4 to -5
                              I thought center collective stick should be roughly 0 pitch and not +4 or am I wrong?
                              Darryl
                              Darryl
                              Eflite Blade MSR
                              Spektrum DX6i
                              BMFA Member
                              • #30
                                Steve
                                well cheers steve ive learnt something today aswell. mine has been the otherway since my first crash which was about a day after i got it whoops
