raptor 30 tail blades?
  • raptor 30 tail blades?
    Could anyone suggest a decent set of carbon tail blades for my raptor 30? Still got plastic tail blades, and want a decent set on the tail, although not to be breaking the bank also
    simon
    Sab Goblin 500
    Depends what you really want out of it. Being a 30.. I think they use 85mm tail blades, so any carbon ones will be an improvement in responsiveness over the standard plastic ones.
    Here are some rotortech ones
    If you check the Midland Helicopters, they have the bbt 85mm tails which are cheaper.
    ANdy - CDMFC
    Align 550 Beast X
    Proud owner of 3 x E.G.S.
      I use the rotor tech 85mm tail blades on mine & Im happy with them!
      Del
      Climb-Out
      3D Scotland
      Proud owner of 2 EGS
        thought it was nearer 92mm? caught between these HobbyKing Online R/C Hobby Store : TIG 93mm Carbon Fiber Tail Blade $10.02#
        and
        Fast Lad Performance
        what do we go for? im liking the white ones, even with my carbon main blades, help!!
        simon
        Sab Goblin 500
          and
          simon
          Maybe.. just measure your old ones.. I thought the 92mm were on the 50 size..
          ANdy - CDMFC
          Align 550 Beast X
            you are dead right, 85mm, showing my inexperience going to go for the bbt tails i think
            Sab Goblin 500
              would the 92mm ones be no good then?
              Sab Goblin 500
                I think that it will not clear the main blades.. If you went inverted and punched it up, it would be very likely that the main blades will make contact with the tail blades.
                ..also the bigger the tail blades, the more power is required to power them. You may find that having only a 30 size heli, the motor will not cope with them.
                ANdy - CDMFC
                Align 550 Beast X
                  If it helps, the 30 and the 50 Raptors both use the same size tail blades in the kit.
                    iv gone for the 80mm sab from midlands carbon, hope they ok Midland Helicopters Ltd Blades_Sab
                    simon
                    Sab Goblin 500
                      Personally, if I was intent on changing the standard tail blades to carbon, I would have gone for one which was the same size. They don't seem to have quoted the chord size, so don't know if they are any wider than your standard ones. Assuming they are the same chord size, they will have less push than the standard 85mm blades.
                      Are you trying to achieve better tail authority/response, or are you just going for cosmetic reasons?
                      ANdy - CDMFC
                      Align 550 Beast X
                        simon
                        Simon,
                        These are what I have on mine - they look much look better and work fine.
                        Very proud holder of 1 EGS
                          simon
                          Could leave you with a very vague tail, not really giving the gyro much help with 80mm blades. 92mm would be optimum.
                            I thought 92mm tails just cleared on a raptor 50 and would be too long on the 30 as it could make contact with the main blades in manouvers. ie fast inverted climbouts.. or any pitch pumping.
                            Maybe wrong.... long time since I had a Raptor but quite sure on it.
                            ANdy - CDMFC
                            Align 550 Beast X
                              Not as l remember but some 550 blades are not always 550 so you`d have to watch that. 92mm is right on the limit. 85mm will work fine for most of us.
