Guys,
I've been here for about a year now and am loving my heli flying and am starting to get in to EDF Jets. My understanding of brushless motors and ESCs really comes from listening to you guys so I thought it was about time to check my understanding before I build or buy any more kit to throw in to a jet or heli. Can you please confirm that the following is correct:
Guys, sorry for the long post, but this is crucial stuff and I really want to learn how to build my own set-ups so I'd also be grateful for any links to good websites or guides. Any corrections to the above will also be appreciated as I know there are some really technically-minded dudes out there.
Many thanks,
Si
- The speed that a motor turns at is a function of voltage delivered and KV rating so a 3000KV motor with 10v will turn over at 30,000rpm
- In doing so, the motor will draw the current it needs to sustain that speed depending on the load (within reason)
- The ESC will deliver whatever current is required up to its rating to sustain the speed that you set via the throttle.
- Provided that the ESC and motor are rated for the voltage you are using, there are a number of ways to achieve the same power requirement: eg to achieve 2000rpm headspeed in a hover with 3.5 Kg TREX 600E, you could use a low voltage (6s) with a high kv-rated motor and (for example) 10:1 gearing. Equally you could use a high voltage (12s or 10s) with the same gearing and a lower kv rated motor. In the latter example the amps pulled will be less so less MAH batteries will be required, in the former example you'll need more MAH to deliver the current.
- If all this is right, then to achieve my 2000rpm headspeed at 10:1 I'll need 20,000rpm motor speed. I could do this by using a 2000kv motor at 10 volts (about half power at 6s) or a 1000kv motor at 20 volts (about half power at 12s)
- However, I could also run a 12s set up with the 2000KV motor provide I changed the gearing to 5:1. (assuming that motor is happy turning at that crazy speed!)
- So, with the same overall performance, I could run a TREX 600E with a pair of 6s 2800mah batteries in two entirely different ways. Either put the batteries in series to work as 12s 2800mah or put them in parallel to work as a 6s 5600mah. (I accept that the 6s solution is easier to implement on a standard TREX600E as a 12s solution will require new components. I'm just trying to understand the maths here)
- Or, using a TREX 500 as an example, a 6s 3000mah setup will have similar endurance and performance to a 5s 3600mah setup provided that the gearing is optimised. (Volts * mah the same in both cases)
- And now a bit on ESCs: an ESC will deliver between 0% and 100% of the LIPO voltage available. So when the battery starts to fade, the max rpm of your motor will drop too. So in crude terms (provided the ESC is rated for the voltage) 50% stick when working on 3s gives out about 5.5 volts (11.1 volts on 6s) and at 100% 11.1 volts (22.2v on 6s). All voltages are nominal. (I've seen a video where an EDF jet model was flown on 4s even though the motor and ESC were only rated for 3s. The extra voltage gave brilliant take-off performance but risked a burn-out if used excessively. My theory is that provided the throttle was kept below 3/4 then you could run like this indefinately because the voltage would be the same as 3s)
- I can fit a massive rated ESC (say 200A) in to a TREX 450 (usually 30-45A) with no fear because it won't "push" amps, the motor will "pull" them. The bigger ESC is only a problem in terms of weight and cost.
Many thanks,
Si
compatible.
