gutted
  • gutted
    hi all realy guted today ,fitted brushles motor + esc hovering great tail in no prob at about 4feet then all of a sudden after about 5 mins the heli decided to go to the left and caught a gate and smashed the main blades .ok ,so i smashed the blades i thought thats no problem, fitted some more within 5 mins and nothing the power is there but the motor will not spin could i have damaged the esc regards martyn
    Sorry to hear about that Martyn, What heli were you flying at the time,
    check to see if you have voltage output from the esc.
    TDR (in progress)
    SAB Goblin 700
    Vibe 90SG Vibe 500E
    Kalt Baron30
      it is the dragon fly 60
      thanks martyn
        If you smashed the blades you probably have other damage such as a bent main shaft, inner shaft - take the motor out and see if it spins isolated from the main gear and if the main gear is able to be turned over by hand. Also check the plugs into the receiver havent been pulled out.
        You might get some more specific help from the 60 forum at:
        http://www.walkera-heli.com/forum/vi...152a928ada711e
        John
        John
          cheers john .
          no the motor does not spin even when i take it out but if i put the brushed motor back thats fine regards martyn
