Neon Blaze CP main gear change.
  • Neon Blaze CP main gear change.
    Good Afternoon all,
    well, actually it's not to good !!. My Neon Blaze has just landed in an uncontrolled manner !!. Everything seemed to be ok when I checked it over, I then throttled up again and nothing happened, on a closer inspection I found the teeth on the Main Gear have been rounded off and therefore no longer works !!. I've been trying to search for a manual / instructions on how to change the main gear and cannot find anything on the web, can anyone help me please ??
    Cheers in advance
    Jim.
    hi Jim,,,try Century uk, http://www.centuryuk.com/Products/He.../Neon+Blaze+CP
    ,,this should link you to the spares for your heli
    edit:-,,,ah, you want to know HOW to change the main gear ? not had any experience with the Blaze, but the mini t is easy enough, undo and take out the retaining bolt in the taildrive gear, undo the two grub screws in the bottom retaining collar, then lift the whole head assy. off, replace gear, then head assy,, collar, bolt,,,,robert is your mothers proverbial,,,dunno about your blaze though,,,sure someone will be along to sort you out,,,
    (btw, your main gear is designed to be "sacrificial" in as much as they are usually only a couple of quid, and relatively easy to replace )
      Jim, any problems I live in Folkestone and in Dover 50% of the time, let me know if you have are stuck.
      x 3
        Cheers guys, thanks for the help. I've ordered the part now so i'll see how i get on, Paul, you may well be hearing from me very soon !!!!!.
          No problem
          x 3
