TREX 450X servo setup needed
  • TREX 450X servo setup needed
    Just bought TREX 450X 120' swashplate but instructions for servo installation and setup are very basic , need some help here I'm using a JR3810 and switched to heli mode ,changed stick mode to allow throttle on left stick as I prefer this. Firstly what servo movements should I expect when when I give left or right and forward and back on right stick etc. any help would be appreciated .......................... how do I set up mixing ? etc. Thanks in anticipation as my only RC experience is in gliders
    Hi there,
    Take a look at the finless videos located here:
    http://www.helifreak.com/viewforum.php?f=95
    You will need to register to download them, but it's free. THey are very good but they cover the Futaba TX not the JR, but I am sure they will help you along no end.
    The forum thread you might be most interested in is this one:
    http://www.helifreak.com/viewtopic.php?t=12455
    The "CCPM Setup Part 1" video will explain the answers to your questions in the your post.
    Viewing the heli from the rear, forward should lift the rear servo and lower the front left and right. Back is the reverse.
    Roll left will lower the front left and raise the front right, Roll right should be the reverse.
    Pitch up should see all servos move upwards. Pitch down is the reverse.
    It's all in the video I mentioned above
    Hope that helps.
    Last edited by jiberjaber; 29-10-2006, 07:26 PM. Reason: added more specific links
    Regards,
    Jason
      many thanks will let you know how I get on .....................
        They are great videos i am glad someone took the time to make them
        Butuz
        Heli 1: Mikado Logo 400 3D
        Heli 2: RCer Dragonus 450
        DX7SE / Cellpro 10s Keeping me in the air!!!
        Gaer Park Model Flying Club
          I've downloaded the Videos and now making great progress,
          Many Thanks for the Vids...........So helpful
            Thanks Guys my problem was the RCX6 receiver channel markings were different causing my mixing problems, now corrected and had my first few flights Great!!!!!!!!!!!!!
              Excellent, glad your in the air at last
              Regards,
              Jason
                Thanks Jason for pointing me in the right direction >>>>>>>>>>>>>>>>>
                Alan
                TREX 450X
