eco 8 swashplate
  • eco 8 swashplate
    damaged the standard swash on my eco 8 today got the aluminium swash to fit but not sure if its all intacked is there any way of getting a photo of it on this site for some apinion thanks marty
    Hi, not sure what you want to see, here is the real one !
    Fly today, tomorrow it may be too late !!
    http://www.ukheli.com for my T-Rex 600e / 600n build site
      hi martynm yep thats the 1 but on the under side should there be something plastic or metal that goes in the middle were the bearing goes the small bearing whis is shown on the the photo is there cheers martyn
        should the rose joint be tight or can you push it out as the one i have comes out is that a good thing or bad regards martyn
          You don't want that coming out
          Mine are all fitted but it don't sound correct to me. I will have a better look when I am at home. No swash plates I have ever seen can you push the center ball out, it is sometimes tight when new, where did yours come from? They are about £70 new.
