mini t flybar
  • mini t flybar
    Finally got my mini t in the air after purchasing one from ebay 2 months ago, got about 6 inches off ground and it starts to ocsillate pretty badly, took it back indoors, feathering shaft ok, main shaft looks ok, although havn't fully removed it, but I have a slightly bent flybar! must have come bent when i bought it. Just wondering whether this would make my heli do tail circles so badly?!
    Sab Goblin 500
    Very unlikely.
    could be main shaft.
      Yup, prob the main shaft, get a video up.
      As said, I cant see it being hte flybar, I normally just bend mine back straight'ish all the time.
      x 3
        yep i agree... mainshaft... alot of guys just bend the flybars back and ive never seen what you are describing after they have done that.
        Lee
        www.raptoruas.co.uk
        www.lee.rcha-uk.com
        www.gensace.de
          looks like it could be that then, problem now is took part of the head down, unlocked the top collar and tried to unlock the collar above the main gear, using an allan key, think iv knackered the bolt fitting, now the allan key spins round and doesn't bite, bit clueless how the get it off now, any ideas?
          Sab Goblin 500
            I had a similar problem and that's why i now own a dremel,Your gunna have to grind it off i think mate.A tool like a dremel is a must have in any modellers tool kit IMO.They have cheap ones at Maplins aswell.
            Proud owner of 2 Eddie Gold Stars!
              yeah thats what I was thinking mate, just hoped theyd be a magic solution from more experienced rc heli addicts, never mind, just a shame really just more time now to get it done, back to the raptor for the time being then , thanks everyone anyhow
              by the way which drill to you go for and how much if you don't mind me asking mate
              simon
              Sab Goblin 500
                simon
                The one i have mate is this one;
                Dremel Multi Tool Plus Kit 300-25 125W, 8710364030491
                You can one much cheaper here,That's what i would have gone for if i'd have known beforehand,
                At the moment there is one on sale with the 61 piece tool bits for £14.99,Bargain!
                Rotary Tools : Maplin Electronics
                This is the cheapest one mate;
                http://www.maplin.co.uk/Module.aspx?ModuleNo=223458
                  looks like the £14.99 is the one for me!
                  cheers!
                  Sab Goblin 500
                    cant you drill out the grub screw
                      Simon
                      Which collar are you refering to, is it the collar below the swash plate or the bolt holding the main gear to the mainshaft ?
                      Martin
                      x2
                      Rave 450
                      Trex 250se
                      DX7se
                        the collar that holds the main gear onto the shaft sits just above the main gear
                        Sab Goblin 500
                          Two sets of pointed nose pliers should do the job, grip the allen key end and undo the nut instead.
                          Martin
                          x2
                          Rave 450
                          Trex 250se
                          DX7se
                            will give that a try tmrw cheers!!
                            Sab Goblin 500
                              If you have the 325se model with alloy head then good chance its that, I crashed mine year back now but took weeks to find it was the head that caused same fault as your explaining
                              • Flickr Through My Pictures.
