Twister Skylift Help
  • Twister Skylift Help
    I have recently bought a secondhand Twister Skylift Chinook which has been working perfectly, less said about the pilots skills. I recharged the 2 batteries I have the the heli, connected them up the 3-in-1 unit LED shows a RED light and not a GREEN light as shown in the instruction manual. Both batteries are fully charged. I can operate the Cyclic control stick and there is movement, but on operation of the Throttle/Yaw stick there is nothing.
    All help or ideas would be most appreciated.
    does the transmitter battery lights flash when you switch it on?
    if so you have to arm it,so make sure you plug in the battery when it is flashing to make the throttle arm.
    also make sure the throttle trim is all the way down to the bottom.
    see how you go.
      Move the throttle trim switch all the way down.
      • Flickr Through My Pictures.
