binding esc's
  • binding esc's
    i have just relaced my esc on my spirit now the tx won't recognise it so i am assuming i need to bind it,can someone tell me how to do it (idiots guide please) and can i bind it to the original tx and my dx6i
    thanks andy
    If it is a 2.4 system then yes you would have binded it using the bind plug. if it is 35mhz then you need to change the crystal in esc over from the old one. But as you are using a DX6I it must be 2.4
    Put the bind plug in to any free slot on the esc (a 4in1 unit is it) then turn on, (make sure on the dx6i that you have to correct model selected in the tx) then holding the trainer switch forward power on your DX6I and keep hold of the trainer switch until the binding light on the rx or 4in1 stops flashing and the light stays on then the heli is bound to the tx.
    Mike, 3rd Hampton Scout Group
    Spectrum DX7
    Piper Pawnee 40
    Wot Trainer, OS 46Fx
    3D 400
    P68C Scale twin
    SRCMC
    Pround owner of an EGS
      Bind a speed controller?
        Yes that what i thought? but I'm assuming he means a 4in1 or 3in1?
        Spectrum DX7
        Piper Pawnee 40
        3D 400
        P68C Scale twin
        SRCMC
          im not sure you can bind it to a dx6i its not dsm2. are there not instuctions in your manual for binding your original tx?
            Well spotted Boggy I missed that one
            Spectrum DX7
            Piper Pawnee 40
            3D 400
            P68C Scale twin
            SRCMC
              it's the reciever control box i replaced like this one
              http://www.centuryuk.com/Products/He...Spirit+?pos=22
              how do i get the original reciever that came with the helicopter to recognise it
                ive never bound a century tx andy but ill take a punt.
                if its the same as a eflite tx in the way it works it will bind itself.
                switch off the tx.
                connect the helicopter battery the esc lights should blink
                make sure the throttle is down and switch on the tx. if it is the same it will go into bind mode for the first ten seconds or so. you should then get a twitch or buzz from the heli and the lights should all be steady. and your done
                ready to fly
                like i said its just a punt but worth a try (you may want to hold the heli down by the skids whilst doing this)
                have a good look around the tx if there is a button marked bind do the above but hold the button whilst switching on. till you get the twitch
                  switch off the tx.
                  ready to fly
                  thanks i've been doing that and it's not connecting, can't see any bind button on the tx
                    ive looked on the century web site and cant find a manual for yours so im afraid thats all i can do for you. the only other i can suggest thing is try the proccess with each switch in turn.
                      i went on the century site as well, looks like a trip back to the shop on wednesday.
                      thank you very much for trying to help me, i will try each switch individually
