Flybars
  • Flybars
    i have a kyosho caliber 30 i got cheap and the fly bar seems to be a little longer than it should be will it be ok what affect will it have
    the fly bar is 3mm ive seen better deals on other makes of 3mm fly bars can you use any ones brand of 3mm fly bar or is this a deff no no
    the kyosho 1 is around 400mm the raptor ones are 395mm
    just looking for a cheaper alternative
    Gaza07
    Trex 500esp 6s Beast-X V3
    Trex 600esp 12s Beast-X V3
    A few Multi Rotors
    the raptor one should be fine. does the standard one have any flats on it?
    Ade
    www.accurc.com
    adrian@accurc.com
    This is an apple free zone
      the standard one has the threaded ends and has grub screws in the ends of the paddles to lock em on but no flats on the bar altho im not sure the one thats fitted is the standard bar as its longer than described in the manual
      Gaza07
      A few Multi Rotors
        sounds like the raptor one should be perfect
        Ade
        www.accurc.com
        adrian@accurc.com
          Guys, sorry to hijack this thread but I had a bit of a hot start on Sunday on my Raptor 50 when I forgot to switch the rx on and the flybar got a touch bent on one side as it went into my hand - only a touch.
          I tweaked it back straight. Is that ok? Seemed to fly ok with no vibration.
          At least I know why I hold the head when starting my heli now
          Cheers, Lee.
          Proud recipient of an EGS
            its been work hardened now. so its going to be more brittle.
            I would change it personally.
            Ade
            www.accurc.com
            adrian@accurc.com
              what about the one thats fitted thats to long its not bent or twisted
              what affect will a fly bar being to long have on the model
              leebert no worries its a flybar thread lol
              Gaza07
              A few Multi Rotors
                Ade
                Thanks Ade
                Is the standard mild steel flybar ok or is a stainless steel one the one to have? I could do with a bit more response / speed to the cyclic. Or do I need some V paddles really?
                Cheers, Lee.
                  V Paddles will definitely help with cyclic response
                  I run them myself and they perform very well!
                  | 3D Championship
                    Gaz a longer flybar would mean the paddles are further out,should make it more stable
                    I prefer mild steel flybars as they are more pliable,the stainless ones fracture easily and hate being straightened
                      cant beat Vs!
                      Ade
                      www.accurc.com
                      adrian@accurc.com
                        Raptor50luvver / Ade:
                        I was thinking that a Stainless Steel flybar would be stiffer and give better response? Am I right or is the difference negligible??
                        Cheers, Lee.
                          very little, i think stainless doesnt work harden as easily as normal steel tho?
                          Ade
                          www.accurc.com
                          adrian@accurc.com
                            Thanks Ade.
                            The main reason for asking is that you get 2 mild steel ones for the price of a SS one. If the difference is so small I'll get the mild ones.
                            I was given a pair of 'V' paddles that have lost the little metal bushes in the end (common apparently). I am trying to find an alternative to the little bush and I think I have found a cable ferrule that will do the job. Pass the 5 min epoxy
                            Cheers, Lee.
                              Stainless is harder than mild steel as it has a large quantity of other metals added to it (chrome, nickel, etc). It does work harden very easy. However it don't rust, and has a greater tensile strengh so its swings and roundabouts realy. (oh god I have posted again hope this don't all get out of hand.....)
                              And a DX8 too
