Hi guys. I actually found this site through sheer frustration & i think its fantastic! I am new to RC Helicopters but i have had 3 different ones for about 18 months but not used them since i first brought them. I brought the M.A.S.H, Twister Coastguard & Honeybee king 2 helicopters. I got that fed up with smashing them that i put them in my shed to rot! Well, about a week ago i got the bug back again & this time i wont give up no matter how much it costs!! (within reason) The one that i cant do anything with is the Honeybee king 2. When i first had it i couldnt stop the tail turning no matter what i did. It turned as much as the blades & this is why i gave up with it. Anyway, i have now fetched it back out & i have tried & tried to get the tail to stop spinning & my lack of experience isnt helping & i cant do anything with it. Any advice would be greatly appreciated. Great site guys.
My first post.
Hi Steve and welcome to the forum..
You've come tothe right place for great advice and help.. Unfortunately i have no experience with the HBK2 but i think a few mwmbers do have them (or did in the past), so i'm sure someone will offer you some help with the problem..
MoAvant Aurora|Trex 700LE
Trex 600NSP|Outrage G5
Beam E4|Twister Storm
Trex 250|mSR|mCX|4#3B
DX7|1 EGS!
hi steve
welcome on board , lots of help on here i also have never had an experience with the HB2 but iam sure some one will help you
good luck in the future
ps have you got a sim thats a must to start with
stevekasama srimok 90n
T rex 700 Ys91sr futaba bls 452 GY520+bls 251 aerospire gov Fromeco reg
Futaba 10c
empty bank account
Hi Steve.
Keep at this time buddy and many members on here will help and get you flying I'm sure.Mike, 3rd Hampton Scout GroupSpectrum DX7
Piper Pawnee 40
Wot Trainer, OS 46Fx3D 400P68C Scale twinSRCMCwww.controltower.pwp.blueyonder.co.uk/1.html
Pround owner of an EGS
The gyro might be in reverse... (should be a switch on the gryo to change it)
Or - http://www.rcheliaddict.co.uk/blogs/...tail-tale.htmlDandeman
x4 eddie Gold star
-Sceadu 50
-wildcard plank
-xray seagull plane
-phoenix and dx7
Howdy,
I've got a honey bee king 2, and I hate it lol.
1.Does the little red light on the Gyro flash?
2.Let it flash for about 13 seconds
3.DO NOT MOVE THE HELI UNTILL THE LIGHT HAS STOP BLINKING
4.if the tail keeps spinning, try moving the tail servo forward or backward, if it is spining to the right, move the tail servo to the nose a bit, if it is spining left move to the back a bit.
5. if it is still spining try moving the little dial on the gyro, fiddle about with it untill it flys good.
I have a Esky HH gyro for sale, much better than the stock gyro. £15?? Pm if you want it.I left the hobby 3 years ago and discovered Women.
I wish I never left.
Hi Steve
I do not have a HBK2, but I do have an Esky Cool, which is very similar, and the sweetest little bird you could wish for.
Sounds to me a gyro problem, so first check everything is moving in the right direction.
Before these, it might be an idea to unplug the motor. You will be playing with a hot heli, so safety first.
Check 1 stick direction.
Switch on, and let everything settle for a few moments.
Now, rotate the head until one of the tail blades is upright. From the rear, tilt the upright blade back towards you to about 45 degrees.
If you push the rudder stick to the left, the blade should move to the right, and vice versa.
If it goes the right way, move on. If it doesn't, need to reverse the rudder channel,
channel 4 on the transmitter
Now to gyro sense.
If you have gain control on the gyro, turn it up to full, makes the movement easier to see.
Now, push the rudder stick to the left. Note the way the servo behaves. Does it pull the rod away from the tail, or push it towards it?
Centre the stick, and then quickly flick the tail of the heli to the left. The servo should move in the same direction as earlier
In other words, the gyro is mimicking the correcting movement you would make on the stick.
My suspicion is you will find it moving the opposite way. If so, you need to reverse the gyro.
Not sure which one you have fitted. Do these checks, and then let me know the results, then we'll see.
Worth perservering with this heli. It will fly a treat.
Hope this helps
Jeff
Welcome to the forum Steve......
Helis, banter, you name it, it's all here and it's great.....so enjoy..
Cheers Eddie
Beam E4 Scorpion 2221-8-DS760 S9257-Hitec 5065MGs-AR7000-Revolectrix 3s 2200-Radix Main & TailTrex 500CF (Torque tube Upgrade) GY401 S9257-Hitec 5245MGs-AR6200 - Revolectrix 6s 3300Twister Storm 3D GY401 - AR6200 - Revolectrix 3s 2100CP Buzzfly and MSR 120DX7Member of the DMHCBe yourself as no one else is better qualified...
Home of the famous "Eddie Gold Star" (EGS)...also on Facebook for family and friends..
Hi Steve
Just had a thought. Silly question, but is your tail rotor rotating in the right direction?
My Cool is shaft drive, but the HBK2 is belt. If you have crashed it, you must have had to reassemble the tail/belt.
Belt needs twisting by 90 degrees, and it is very easy to get wrong.
On most of my helis, with the main rotor going clockwise, the tail, viewed from the rotor side, should rotate anti-clock. I believe this is pretty standard.
Just a thought, but very easy to check.
Let us know how you are getting on.
Jeff
Hi Steve
Can't believe how many people are saying 'buy a better heli'
Don't accept that. I have had several E-Sky pass through my hands, and all have been good fun. Mind you, to really seal my fate, I like Walkeras as well.
Confession is good for the soul.
Rather than drastic measures, lets work the problem systematically. Let me know how far you have got with your checking.
If worst comes to worst, rather than abandon it, send the whole plot to me. I will fix it, for cost of post, plus any bits I replace.
Think of this as a last resort.
With the combined expertise of this forum, I think we can guide you to a solution. The experience you gain, if you sort it yourself, will be well worth the time.
Jeff
Welcome Steve
