R168DF Receiver
  • R168DF Receiver
    Out of the blue, with no changes to my setup on my Trex XL, the main rotar pitch was not reaching its full travel. I tested the servo on another channel and it attained full travel. Checked my end points were ok (100%) on channel 6. Do you think I have a fault on channel 6? all other channels are fine. I just bought the receiver over a week ago. I dont know if it has anything to do with the ESC but that seems fine although I noticed the red light coming on with my throttle at 3/4 stick. My throttle is set to 0,75,85,95,100 it may be I never noticed it before! I have a pitch curve of 38,50,65,80,100 - this did give me -3 to +10. Any help would be appreciated. Just need to know if im on the right track suspecting the Rx!
    T Rex 600CF 2xTP4500, 2xTP5000,
    what transmitter is this?
    Ade
    www.accurc.com
    adrian@accurc.com
    This is an apple free zone
      Its a futaba 6exh.
        A couple of ideas...
        Is it CCPM? - Is the Swash value different?
        Have you changed the ch 6 end points at all?
        I don't know the 6exh so I may be barking up the wrong tree.
        Cheers, Lee.
        Proud recipient of an EGS
          have you tried it on a different model memory? Make sure you reset the memory to default values.
          Ade
          www.accurc.com
          adrian@accurc.com
            My end points are the same and its the HDE T Rex, I will try a new model memory - thanks
