mini titan gyro
  • mini titan gyro
    anyone use the tg6100 gyro on there titan? I'm using a futaba receiver with a ff9, seem like whatever i do with the receiver plugs and gyro can't get it working. any help much appreciated
    Sab Goblin 500
    Does absolutely nothing happen suggesting a total failure of everything at the receiver end?
    More information please.
    What has happened so far?
    What have you tried?
    Where have you plugged what to where?
    What rx are you using?
    Have you verified if anything works?
    What settings have you got in the TX?
    Member of Mk Heli Club
      Now that I have found a description of the device it is not required with the FF9 and something like a 146iP rx. The TG6100 is/was designed for use with a tx that does not support eCCPM setups.
      Have you get the tx set for a H1 type swash as a starting point?
        get some movement on one servo, nothing on tail, and minimal on throttle. reckon im going to give my cheapy twister tx a go because this isn't playin ball at all.
        tx in h1 mode, even tried it in plane mode which the instructions suggest!
        Sab Goblin 500
