What rate to charge my lipos at????
  • What rate to charge my lipos at????
    Hello all, i need to no at what rate (amp) to charge my lipos at on my new imax b6 charger, i have a 1800mah 20c pack, a 2200mah 25c pack and a 2200mah 35c pack, all are 11.1volts. Thanks for the help in advance. Cheers
    For the 1800mah pack charge at a max of 1.8 amps which is equal to 1C. Likewise with the 2200mah packs charge them at a max of 2.2 amps.
    Although i have no solid proof to back this up, if you are not in a hurry to get them charged, charge then with less amps. ie. charge them at 1amp. Some say that it puts less stress on the battery and increases its life... May be complete rubbish, but it makes sense to me!
    Rgds
    Aidi
    700N 700E 550E
      I always charge them at .1 a less what this pack is.
      i.e a 11.1v 1800mah pack i would charge at 11.1v 1.7a.
      but most of the times i put a slow charge into them like 1800mah i charge at 1.1a...
      hope this helps.
      good luck .
        hope this helps.
        good luck .
        Why?
          Originally posted by Tosh View Post
          Why?
          Whats the point shoving max amps into a battery if you are not in a hurry? Fine when at the field and you want to fly, but at home in an evening time when time is not a factor.
          Cant be any worse for the battery charging it slower
          700N 700E 550E
            I think your math is a little off, mate. If you have 4x450's, that equals 1800
            Getting back to the charging.....you're absolutely right. Charging at a lower C will prolong the life of your batteries
            T-Rex 450 SE V1
            65MG/9650/GY401/CF blades/K&B tail blades/2200 Zippys/Rx AR6100
            T-Rex 500 ESP
            DS510/CF blades all around/DS760gyro/DS520 tail servo
            Tx DX7/Rx AR6200
              2200 i charge at 2.5
              Taort 450 pro v2 fbl
              mz18
              proud owner of 2 egs
              sponsored by :
              KBDD International Pilot
                0.5C for the first half a dozen charges on a new pack.
                0.5C when it's not time critical.
                1C when the weather clears and in a rush between p*ssing rain showers.
                Proud owner of EGS x 4
                Owner of the mysteriously morphing signatur
                e
                  Always charge mine at 2C and never had a problem.
