Hello all,
I bought ElyQ recently, it is my first nitro bird.
I have started the engine yesterday, it was running for about 20 minutes and then once i started playing with mixture and the other valve it died and probably i overflooded it with the nitro.
I got all the nitro and oil out, tried to start again, but:
When I spin a starter the blades are pushed as well, like there is no clutch.
I have disassembed all unit checked nuts etc and I have strange feeling that clutch bearing works wrong way (it was perfect before).
Did you see any issue like that before - friend of mine has similar problem with ElyQ but for him starter does not pull blades that strong...
Thanks for help!
Regards,
Michal
Thanks for help!
Regards,
Michal
